Had leak in tub to pump hose, replaced it. Also installed new belt since it did not seem to be spinning out water as well. Pump appeared fine. Have attempted numerous times to balance, appears to be balanced, but it is banging severely in spin, jumping around floor and it sounds like the tub will come thru the front panel. Not sure what else to do. Help!
You have been a member since:: 3/29/2009(UTC) Posts: 11,699
Unfortunately this type of problem really requires an on site inspection of the machine. Here is a service manual. I can only suggest you take check out the support system for something that was broken during the repair or something that is not in there correctly. http://repair2000.com/Li...maytagatlantiswasher.pdf
