Discuss
Frigidaire washer timer won't advance
 in
Washer Repair
Timer won't advance at all. When advanced manually all cycles work OK. Do I need to buy a new timer?
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire washer timer won't advance
  #1 (permalink)
Old 12-21-2009, 04:23 PM
Junior Member
myura46 is on a distinguished road
Default Frigidaire washer timer won't advance
Model Number: CRTF1240AS0   Brand: Frigidaire   Age: 5 - 10 years
Related Models
Frigidaire CRTF1240AS0 Frtld Washer - Frigidaire
Frigidaire CRTR9300AS0 Frtld Wshr - Frig/best Buy
Frigidaire CRWS1879AS0 Washer - Frigidaire/best Buy
Frigidaire CRWS1879AS2 Washer - Frig/best Buy
Frigidaire CRWS5700AS0 Fs Washer - Frig/best Buy
Frigidaire CRWS7900AS0 Fs Washer - Frig/best Buy
Frigidaire CRWS7900AS1 Frigidaire/washer
Whirlpool CS20TKXNQ00 REFRIGERATOR
Crosley CS20X6A REF - SXS
Crosley CS20X6W REF - SXS
Crosley CS20Y6A REF - SXS
Crosley CS20Y6W REF - SXS
Crosley CS21A2A REF - SXS
Crosley CS21A2Q REF - SXS
Crosley CS21A2W REF - SXS
Crosley CS21A5DA REF - SXS/I&W
Crosley CS21A5DW REF - SXS/I&W
Crosley CS21B5DA REF - SXS/I&W
Crosley CS21B5DQ REF - SXS/I&W
Crosley CS21B5DW REF - SXS/I&W
Crosley CS21F2Q REF - SXS
Crosley CS21F2W REF - SXS
Crosley CS21F5DW REF - SXS/I&W
Crosley CS21G2Q REF - SXS
Crosley CS21G2W REF - SXS
Crosley CS21G5DQ REF - SXS/I&W
Crosley CS21G5DW REF - SXS/I&W
Whirlpool CS22AEXHN00 REFRIGERATOR
Whirlpool CS22AEXHN01 REFRIGERATOR
Whirlpool CS22AEXHN02 REFRIGERATOR
Whirlpool CS22AEXHW00 REFRIGERATOR
Whirlpool CS22AEXHW01 REFRIGERATOR
Whirlpool CS22AEXHW02 REFRIGERATOR
Whirlpool CS22AFXKB05 REFRIGERATOR
Whirlpool CS22AFXKB06 REFRIGERATOR
Whirlpool CS22AFXKQ00 REFRIGERATOR
Whirlpool CS22AFXKQ01
Whirlpool CS22AFXKQ03 REFRIGERATOR
Whirlpool CS22AFXKQ04 REFRIGERATOR
Whirlpool CS22AFXKQ05 REFRIGERATOR
Whirlpool CS22AFXKQ06 REFRIGERATOR
Whirlpool CS22AFXKS05 REFRIGERATOR
Whirlpool CS22AFXKS06 REFRIGERATOR
Whirlpool CS22AFXKT00 REFRIGERATOR
Whirlpool CS22AFXKT01
Whirlpool CS22AFXKT03 REFRIGERATOR
Whirlpool CS22AFXKT04 REFRIGERATOR
Whirlpool CS22AFXKT05 REFRIGERATOR
Whirlpool CS22AFXKT06 REFRIGERATOR
Whirlpool CS22CFXTB00 REFRIGERATOR
Whirlpool CS22CFXTB01 REFRIGERATOR
Whirlpool CS22CFXTQ00 REFRIGERATOR
Whirlpool CS22CFXTQ01 REFRIGERATOR
Whirlpool CS22CFXTS00 REFRIGERATOR
Whirlpool CS22CFXTS01 REFRIGERATOR
Whirlpool CS22CFXTS02 REFRIGERATOR
Whirlpool CS22CFXTS03 REFRIGERATOR
Whirlpool CS22CFXTT00 REFRIGERATOR
Whirlpool CS22CFXTT01 REFRIGERATOR
Whirlpool CS22TKXNQ00 REFRIGERATOR
Crosley CS22Y7DA REF - SXS/I&W
Crosley CS22Y7DW REF - SXS/I&W
Crosley CS23A6DA REF - SXS/I&W
Crosley CS23A6DW REF - SXS/I&W
Crosley CS23B5A REF - SXS/I&W
Crosley CS23B5Q REF - SXS/I&W
Crosley CS23B5W REF - SXS/I&W
Crosley CS23B6DA REF - SXS/I&W
Crosley CS23B6DQ REF - SXS/I&W
Crosley CS23B6DW REF - SXS/I&W
Crosley CS23G5Q REF - SXS/I&W
Crosley CS23G5W REF - SXS/I&W
Crosley CS24G6DB REF - SXS/I&W
Crosley CS24G6DQ REF - SXS/I&W
Crosley CS24G6DW REF - SXS/I&W
Crosley CS25A7DA REF - SXS/I&W
Crosley CS25A7DB REF - SXS/I&W
Crosley CS25A7DQ REF - SXS/I&W
Crosley CS25A7DW REF - SXS/I&W
Whirlpool CS25AEXHN00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool CS25AEXHW00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool CS25AFXKQ00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool CS25AFXKQ01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool CS25AFXKQ02 REFRIGERATOR
Whirlpool CS25AFXKQ03 REFRIGERATOR
Whirlpool CS25AFXKQ04 REFRIGERATOR
Whirlpool CS25AFXKQ05 REFRIGERATOR
Whirlpool CS25AFXKT00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool CS25AFXKT01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool CS25AFXKT02 REFRIGERATOR
Whirlpool CS25AFXKT03 REFRIGERATOR
Whirlpool CS25AFXKT04 REFRIGERATOR
Whirlpool CS25AFXKT05 REFRIGERATOR
Crosley CS25B7DB REF - SXS/I&W
Crosley CS25B7DQ REF - SXS/I&W
Crosley CS25B7DW REF - SXS/I&W
Whirlpool CS25CFXTQ00 REFRIGERATOR
Whirlpool CS25CFXTQ01 REFRIGERATOR
Crosley CS26G3W REF - SXS
Crosley CS26G7DQ REF - SXS/I&W
Crosley CS26G7DW REF - SXS/I&W
Crosley CS26G8DB REF - SXS/I&W
Crosley CS26G8DQ REF - SXS/I&W
Crosley CS26G8DW REF - SXS/I&W
Crosley CS26G8DZ REF - SXS/I&W
Crosley CS26G9DB REF - SXS/I&W
Crosley CS26G9DQ REF - SXS/I&W
Crosley CS26G9DW REF - SXS/I&W
Crosley CS26G9DZ REF - SXS/I&W
Crosley CS27G6DB REF - SXS/I&W
Crosley CS27G6DQ REF - SXS/I&W
Crosley CS27G6DW REF - SXS/I&W
Whirlpool CS5000XSW0 Residential Dryer
Whirlpool CS5000XSW1 Residential Dryer
Whirlpool CS5000XWW0 Residential Dryer
Whirlpool CS5005XWW0 Residential Dryer
Whirlpool CS5100XSW0 Residential Dryer
Whirlpool CS5100XSW1 Residential Dryer
Whirlpool CS5100XWW0 Residential Dryer
Whirlpool CS5105XWW0 Residential Dryer
  #2 (permalink)
Old 12-22-2009, 05:27 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Probably so, but first take off your timer and check the contacts and the wiring, particularly those two black wires. Make sure all the connections are clean and tight.
If you still have the problem replacing the timer will probably solve your problem. Here is the part, fortunately not too expensive for a timer.
Part number: AP2108034
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer fills, timer doesn't advance, nor does it agitate, spin, or drain threads68 Washer Repair 3 01-17-2010 02:47 AM
Kenmore washer timer will not advance past the wash cycle, will not spin or drain H20 ambsdr4god Washer Repair 1 11-09-2009 08:21 AM
how to install timer in A frigidaire washer goldwingdandj@frontiernet Washer Repair 1 05-15-2009 05:35 PM
Frigidaire Washer: Need to install new Timer vane15245 Washer Repair 1 05-14-2009 06:27 PM
Timer will not advance geraki Dishwasher Repair 3 12-11-2008 03:05 PM
