I had an F11 and a dl error code. The door lock consistently stuck in the lock position after pressing pause until I replaced the ECA or ccu all the same in my duet. The washer ran perfectly the first time but now flashes the F11 again. I can hear the timer moving , but the washer does not start and the F11 appears. However, once I push the pause button, the door now unlocks. Help
Is the user control panel the problem
