Discuss
frigidaire front load washer will not go into final spin
 in
Washer Repair
Front load Frigidaire washer goes thru the cycles as usual until the final spin. The drum will go back and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » frigidaire front load washer will not go into final spin
  #1 (permalink)
Old 12-20-2009, 06:57 AM
Junior Member
cubbie23 is on a distinguished road
Default frigidaire front load washer will not go into final spin
Brand: Frigidaire   Age: 1 - 5 years
Front load Frigidaire washer goes thru the cycles as usual until the final spin. The drum will go back and forth but will not do a high speed spin
Ads By Google
  #2 (permalink)
Old 12-22-2009, 04:01 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
If you post a model number someone may be able to help you.
__________________
  #3 (permalink)
Old 02-12-2010, 12:40 PM
Junior Member
FILTTY is on a distinguished road
Default no final spin
the inside of yuor door is a sticker stating that small loads will not spin out try a big load i just saw sticker im hoping that is my problem 2 good luck
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire front load washer will not spin Merlis Washer Repair 14 12-06-2012 04:08 PM
front load frigidaire will not spin on final Danmav Washer Repair 3 12-03-2009 04:24 PM
Frigidare front load washer will not spin durning final spin cyle binky8992 Washer Repair 2 08-19-2009 06:29 PM
Frigidaire front load washer won't spin jociadam Washer Repair 1 07-03-2008 06:52 AM
Frigidaire Front Load Washer Won't Spin bbemis Washer Repair 2 11-28-2007 07:46 AM
