Discuss
Tub fills but doesn't cycle
 in
Washer Repair
Tub fills with water but doesn't go to the next cycle, you can hear the the lid switch make
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Tub fills but doesn't cycle
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-20-2008, 08:36 AM
negrell negrell is offline
Junior Member
negrell is on a distinguished road
Default Tub fills but doesn't cycle
Model Number: WWA8630SBLWW   Brand: GE   Age: More than 10 years
Tub fills with water but doesn't go to the next cycle, you can hear the the lid switch make contact and the timer is buzzing. I found a part called "Actuator catch lever" (p/n AP2044599) on the ground under the washer which is part of "shifter assembly" (p/n AP2045698), could this missing part be causing the washer not to cycle? The part is not a stock item, 7-10 days. I think I have all the parts to reattach the lever and 2 springs to assembly. Also, found oil under the wash machine.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-21-2008, 01:20 PM
Junior Member
Unhappy Repost - Tub fills but doesn't cycle
Any idea if the condition described below is causing my problem of the cycle not starting? Please advise, posted yesterday morning.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer fills on wash cycle and rinse cycle and won't stop filling! riphinney Washer Repair 15 03-12-2008 05:30 PM
Washer tub fills with water after the spin cycle completes vinnyvmj Washer Repair 0 02-17-2008 09:09 AM
Tub fills with water JoelK Dishwasher Repair 3 01-23-2008 01:03 PM
Fills and stops metten2@verizon.net Washer Repair 9 01-08-2008 01:57 PM
Washer fills when off kbncpa Washer Repair 1 11-04-2007 11:49 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
