Discuss
Motor Making Noise and Washer won't run
 in
Washer Repair
I tried to run the washing machine and it attempts to run but the tub will spin slowly motor sounding
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Motor Making Noise and Washer won't run
  #1 (permalink)
Old 12-16-2009, 05:37 PM
Junior Member
DonC377 is on a distinguished road
Default Motor Making Noise and Washer won't run
Model Number: WM2277H   Brand: -other-   Age: 1 - 5 years
I tried to run the washing machine and it attempts to run but the tub will spin slowly motor sounding badle or the motor will just hum and will eventually give a code LE. It almost acts like it's trying to run in both directions at the same time. According to the warranty the motor is under warranty but I have to wonder if it's the motor at all. Could the control board be telling the motor to run in both directions at the same time. I did read another post on here that stated the LE code was a doom and gloom code but not sure if the guy had the same problem as I do.
This machine
Related Models
 WM2277HB Washer
 WM2277HS Washer
 WM2277HW Washer
Jenn-Air WM227B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM227W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM236B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM236W WALLOVEN- S/C MWAVE ELE
 WM2432HW Washer
 WM2442HW Washer
 WM2455HG Washer
 WM2487HRM Washer
 WM2487HRMA Washer
 WM2487HWM Washer
 WM2487HWMA Washer
 WM2496HSM Washer
 WM2496HWM Washer
 WM2677HSM Washer
 WM2688HNM Washer
 WM2688HNMA Washer
 WM2688HWM Washer
 WM2688HWMA Washer
Jenn-Air WM27160B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27160W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2720B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2720W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27260B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27260W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27460B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27460W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2750B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2750W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM277B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM277W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2780B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2780W WALLOVEN- S/C MWAVE ELE
 WM2801HLA Washer
 WM2801HRA Washer
 WM2801HWA Washer
 WM3001HPA Washer
 WM3001HRA Washer
 WM3001HWA Washer
Jenn-Air WM30460B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM30460W WALLOVEN- S/C MWAVE ELE
 WM3431HS Washer
 WM3431HW Washer
 WM3632HW Washer
 WM3677HW Washer
 WM3988HWA Washer
Amana WM612 MWAVE- CNTRTP / STAND ALONE
Amana WM614 MWAVE- CNTRTP / STAND ALONE
Amana WM615 MWAVE- CNTRTP / STAND ALONE
Amana WM712 MWAVE- CNTRTP / STAND ALONE
Amana WM714 MWAVE- CNTRTP / STAND ALONE
Amana WM715 MWAVE- CNTRTP / STAND ALONE
General Electric WMCD2050G0WC Washer
General Electric WMCD2050H0WC WASHER
General Electric WMCD2050H1WC WASHER
General Electric WMCD2050H2WC WASHER
General Electric WMCD2050H3WC WASHER
General Electric WMCD2050H4WC WASHER
General Electric WMCD2050H5WC WASHER
General Electric WMCD2050H6WC COIN-OP WASHER
General Electric WMCD2050J0WC COIN-OP WASHER
General Electric WMCD2050J1WC WASHER
Jenn-Air WME3020B WALLOVEN- S/C MWAVE ELE
Jenn-Air WME3020W WALLOVEN- S/C MWAVE ELE
Jenn-Air WMG3020B WALLOVEN- S/C MWAVE GAS
Jenn-Air WMG3020W WALLOVEN- S/C MWAVE GAS
Whirlpool WMH1162XVB0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVB2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVD2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVQ2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XVS0 MICROWAVE OVEN 1.6 Cu. Ft.
Whirlpool WMH1164XVS1 MICROWAVE OVEN 1.6 Cu. Ft.
Whirlpool WMH1164XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVB0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVB1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVB2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2175XVQ0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVQ1 MICROWAVE OVEN 1.6 CU. FT.
  #2 (permalink)
Old 12-19-2009, 12:58 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
The problem with this code is that it identifies the problem, that is, the main control board does not detect the motor operating, but it does not say where the problem is.
Some folks have had success finding a problem in the wiring between the main control board and the motor and other by replacing the hall sensor which acts as a kind of tachometer.
Here is a service manual which will lead you through some troubleshooting.
http://136.166.4.200/contents/Laundr...ice_Manual.pdf
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer making load noise M. Campbell Washer Repair 0 02-25-2010 03:26 PM
washer making noise land1582 Washer Repair 1 11-13-2009 05:08 PM
Washer is making grinding noise--can I still use? ggluvbug Washer Repair 2 12-30-2008 08:28 AM
Washer making new noise irishtarts Washer Repair 1 12-20-2008 03:56 PM
Maytag washer making noise rjd222 Washer Repair 3 06-24-2008 04:08 PM
