Discuss
Kenmore washer spin cycle
 in
Washer Repair
I have a Kenmore washer that during the spin cycle sometimes will not spin. Sometimes it does. On the times
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore washer spin cycle
  #1 (permalink)
Old 12-16-2009, 01:28 PM
Junior Member
wb64033 is on a distinguished road
Default Kenmore washer spin cycle
Brand: Kenmore   Age: 5 - 10 years
I have a Kenmore washer that during the spin cycle sometimes will not spin. Sometimes it does. On the times it will not spin, I open the lid, hear the solinoid click then shut the lid then it works fine. I have within the past year had to take the unit apart to replace the direct drive gears. Is it possible I did something to it or is something just needing replaced?
Ads By Google
  #2 (permalink)
Old 12-17-2009, 06:01 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Assuming that it did run fine after you worked on the gears then I don't think you did anything wrong and the problem is probably a worn out clutch.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 70 Series Washer - no cold water, weak spin cycle? PHRoberts Washer Repair 3 01-16-2010 04:28 PM
kenmore washer spin cycle does not work saved Washer Repair 7 11-08-2009 02:22 PM
Kenmore Washer, spin cycle not working+ johnwar Washer Repair 1 05-06-2009 09:32 AM
Kenmore Elite washer spin cycle noise Bikerdav Washer Repair 4 04-27-2009 07:56 PM
Kenmore washer making a lot of noise at spin cycle. beldarr1 Washer Repair 1 11-25-2008 04:10 AM
