Discuss
Whirlpool washer wont spin
 in
Washer Repair
My Whirlpool washer LSQ9500LQ0 would not spin correctly, it would slip and you could smell a burning smell. Empty if
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool washer wont spin
  #1 (permalink)
Old 12-15-2009, 05:46 PM
Junior Member
jlrmo is on a distinguished road
Default Whirlpool washer wont spin
Model Number: LSQ9500LQ0   Brand: Whirlpool   Age: 1 - 5 years
My Whirlpool washer LSQ9500LQ0 would not spin correctly, it would slip and you could smell a burning smell. Empty if you would manually spun the tub it would slowly pick up on its own and then work. With this being the problem I replaced the clutch pack. Now the unit will spin...HOWEVER it will not switch from the agitate mode to the spin mode on its own. After it gets done agitating the unit will start pumping the water out and not spin the tub. It won’t even try to move the tub. However if you raise and lower the hood/door then it will kick in and work fine. You can hear a click when you open the lid and it kicks out of gear. So what I am wondering is did I put everything back right? Or could there be another problem like the door switch? But if it were the door switch then why will it work after breaking the cycle then engaging it again? I think it must be in the clutch assy, the drive motor, or the timer switch. Has anyone had this problem? Was the old clutch assy bad? Any info will help thanks.
Related Models
Whirlpool LSQ9500LQ0 WASHER
Whirlpool LSQ9500LT0 WASHER
Whirlpool LSQ9510JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9510JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9510LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9510LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9520LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9520LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9544KQ0 WASHER
Whirlpool LSQ9544KT0 WASHER
Whirlpool LSQ9549LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LG1 AUTOMATIC WASHER
Whirlpool LSQ9549LG2 AUTOMATIC WASHER
Whirlpool LSQ9549LG3 AUTOMATIC WASHER
Whirlpool LSQ9549LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LQ1 AUTOMATIC WASHER
Whirlpool LSQ9549LQ2 AUTOMATIC WASHER
Whirlpool LSQ9549LQ3 AUTOMATIC WASHER
Whirlpool LSQ9549LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LW1 AUTOMATIC WASHER
Whirlpool LSQ9549LW2 AUTOMATIC WASHER
Whirlpool LSQ9549LW3 AUTOMATIC WASHER
Whirlpool LSQ9549PG0 AUTOMATIC WASHER
Whirlpool LSQ9549PG1 AUTOMATIC WASHER
Whirlpool LSQ9549PG2 AUTOMATIC WASHER
Whirlpool LSQ9549PG3 AUTOMATIC WASHER
Whirlpool LSQ9549PG5 AUTOMATIC WASHER
Whirlpool LSQ9549PG6 AUTOMATIC WASHER
Whirlpool LSQ9549PW0 AUTOMATIC WASHER
Whirlpool LSQ9549PW1 AUTOMATIC WASHER
Whirlpool LSQ9549PW2 AUTOMATIC WASHER
Whirlpool LSQ9549PW3 AUTOMATIC WASHER
Whirlpool LSQ9549PW5 AUTOMATIC WASHER
Whirlpool LSQ9549PW6 AUTOMATIC WASHER
Whirlpool LSQ9550PW0 AUTOMATIC WASHER
Whirlpool LSQ9550PW1 AUTOMATIC WASHER
Whirlpool LSQ9550PW2 AUTOMATIC WASHER
Whirlpool LSQ9550PW3 AUTOMATIC WASHER
Whirlpool LSQ9550PW4 AUTOMATIC WASHER
Whirlpool LSQ9560PW0 AUTOMATIC WASHER
Whirlpool LSQ9560PW1 AUTOMATIC WASHER
Whirlpool LSQ9560PW2 Residential Washer
Whirlpool LSQ9560PW3 AUTOMATIC WASHER
Whirlpool LSQ9560PW4 AUTOMATIC WASHER
Whirlpool LSQ9564JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564JQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9564JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564JT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9564JZ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564MQ0 AUTOMATIC WASHER
Whirlpool LSQ9565MQ0 WASHER
Whirlpool LSQ9600JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9600JQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9600JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9600JT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LG1 AUTOMATIC WASHER
Whirlpool LSQ9600LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9600LW1 AUTOMATIC WASHER
Whirlpool LSQ9610JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610JT1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9610LG0 AUTOMATIC WASHER
Whirlpool LSQ9610LW0 AUTOMATIC WASHER
Whirlpool LSQ9620LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LG1 AUTOMATIC WASHER
Whirlpool LSQ9620LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9620LW1 AUTOMATIC WASHER
Whirlpool LSQ9645KQ0 WASHER
Whirlpool LSQ9645KQ1 WASHER
Whirlpool LSQ9645KT0 WASHER
Whirlpool LSQ9645KT1 WASHER
Whirlpool LSQ9650PG0 AUTOMATIC WASHER
Whirlpool LSQ9650PG1 AUTOMATIC WASHER
Whirlpool LSQ9650PG2 AUTOMATIC WASHER
Whirlpool LSQ9650PG3 AUTOMATIC WASHER
Whirlpool LSQ9650PG4 AUTOMATIC WASHER
Whirlpool LSQ9650PW0 AUTOMATIC WASHER
Whirlpool LSQ9650PW1 AUTOMATIC WASHER
Whirlpool LSQ9650PW2 AUTOMATIC WASHER
Whirlpool LSQ9650PW3 AUTOMATIC WASHER
Whirlpool LSQ9650PW4 AUTOMATIC WASHER
Whirlpool LSQ9659LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LG1 AUTOMATIC WASHER
Whirlpool LSQ9659LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9659LW1 AUTOMATIC WASHER
Whirlpool LSQ9659PG0 AUTOMATIC WASHER
Whirlpool LSQ9659PG1 AUTOMATIC WASHER
Whirlpool LSQ9659PG2 AUTOMATIC WASHER
Whirlpool LSQ9659PG3 AUTOMATIC WASHER
Whirlpool LSQ9659PG4 AUTOMATIC WASHER
Whirlpool LSQ9659PW0 AUTOMATIC WASHER
Whirlpool LSQ9659PW1 AUTOMATIC WASHER
Whirlpool LSQ9659PW2 AUTOMATIC WASHER
Whirlpool LSQ9659PW3 AUTOMATIC WASHER
Whirlpool LSQ9659PW4 AUTOMATIC WASHER
Whirlpool LSQ9660PG0 AUTOMATIC WASHER
Whirlpool LSQ9660PG1 AUTOMATIC WASHER
Whirlpool LSQ9660PG2 AUTOMATIC WASHER
Whirlpool LSQ9660PG3 AUTOMATIC WASHER
Whirlpool LSQ9660PG4 AUTOMATIC WASHER
Whirlpool LSQ9660PW0 AUTOMATIC WASHER
Whirlpool LSQ9660PW1 AUTOMATIC WASHER
Whirlpool LSQ9660PW2 AUTOMATIC WASHER
Whirlpool LSQ9660PW3 AUTOMATIC WASHER
Whirlpool LSQ9660PW4 AUTOMATIC WASHER
Whirlpool LSQ9665JQ0 WASHER
Whirlpool LSQ9665JQ1 WASHER
Whirlpool LSQ9665JQ2 WASHER
Whirlpool LSQ9665JQ3 WASHER
Whirlpool LSQ9665JQ4 WASHER
Whirlpool LSQ9665JT0 WASHER
Whirlpool LSQ9665JT1 WASHER
Whirlpool LSQ9665JT2 WASHER
Whirlpool LSQ9665JT3 WASHER
Whirlpool LSQ9665JT4 WASHER
Whirlpool LSR4100HQ0 AUTOMATIC WASHER
Whirlpool LSR4311DQ0 WASHER
Whirlpool LSR5100HQ0 AUTOMATIC WASHER
  #2 (permalink)
Old 12-16-2009, 04:53 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Ok, you did not do anything wrong in installing your clutch and it sounds like it did need replacing. Let me tell you what is probably going on here and how to fix things.
Your machine has a three speed transmission, forward, neutral and reverse. In fact the neutral is called a neutral drain, the reason being that when the timer is ready for the machine to drain water, the transmission goes into neutral so the motor is not trying to spin a tub full of water. Once the water is drained, the machine is ready to start to spin. The way the transmission know this and switches gear is that the motor briefly stops.
In your situation you are not getting the short pause in the motor, so the machine never goes into spin. When you raise the lid, you manually pause the motor, so when you lower the lid the spin begins.
Now if this is the problem the way to fix this is to replace the timer, here it is.
Part number: AP3020314
and fortunately it is pretty reasonable as far as timers go. However, before you spend money try this. Spin the timer knob fast through the cycles a number of times and see if you don't loosen things up. If that doesn't do it, try a few more times. Also, you can open up the console and check and clean the connections. Check to see that nothing has come loose in the timer and that everything looks ok. Sometimes the timer repairs itself in this manner.
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool washer wont spin Braun1 Washer Repair 3 09-28-2009 01:08 PM
Whirlpool Washer wont spin Brewboy1776 Washer Repair 5 04-19-2009 03:27 PM
Whirlpool washer wont rinse or spin ccreechcmc Washer Repair 1 03-21-2009 02:34 AM
Whirlpool Washer wont spin (sometimes) okie2012 Washer Repair 0 10-04-2008 10:26 AM
Whirlpool Washer Wont Spin JLO Washer Repair 4 04-12-2008 07:03 AM
