Discuss
GE Washer
 in
Washer Repair
I recently purchased a water inlet valve from you and everything was working fine until today. The washer fills, but
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Washer
  #1 (permalink)
Old 12-15-2009, 05:11 PM
Junior Member
privilege42 is on a distinguished road
Default GE Washer
Model Number: WWA8350GAL   Brand: GE   Age: 5 - 10 years
I recently purchased a water inlet valve from you and everything was working fine until today. The washer fills, but will not go into the wash cycle. If I manually advance the dial to rinse it will start to spin and drain. I tried to turn the dial to wash mode in other cycles, but no luck.
Ads By Google
Related Models
General Electric WWA8350GAL Washer
General Electric WWA8350GBL Washer
General Electric WWA8354VLL Washer
General Electric WWA8354VML Washer
General Electric WWA8354VNL Washer
General Electric WWA8355BAL Washer
General Electric WWA8355GAL Washer
General Electric WWA8359VCL Washer
General Electric WWA8360BAL Washer
General Electric WWA8360GAL Washer
General Electric WWA8360GBL Washer
General Electric WWA8364VKL Washer
General Electric WWA8364VLL Washer
General Electric WWA8366LAL Washer
General Electric WWA8366LBL Washer
General Electric WWA8480BAL Washer
General Electric WWA8480GAL Washer
General Electric WWA8500GAL Washer
General Electric WWA8500GBL Washer
General Electric WWA8500GCL Washer
General Electric WWA8600GAL Washer
General Electric WWA8600GBL Washer
General Electric WWA8600GCL Washer
General Electric WWA8600RBL AUTOMATIC WASHER
General Electric WWA8600RBLAA Washer
General Electric WWA8600RBLWW Washer
General Electric WWA8600SALAA Washer
General Electric WWA8600SALWW Washer
General Electric WWA8600SBLAA Washer
General Electric WWA8600SBLWW Washer
General Electric WWA8600SCLAA Washer
General Electric WWA8600SCLWW Washer
General Electric WWA8606MAL Washer
General Electric WWA8607SALAA Washer
General Electric WWA8607SALWW Washer
General Electric WWA8607SBLAA Washer
General Electric WWA8607SBLWW Washer
General Electric WWA8607SCLAA Washer
General Electric WWA8607SCLWW Washer
General Electric WWA8608MAL Washer
General Electric WWA8608MXL Washer
General Electric WWA8610SALAA Washer
General Electric WWA8610SALWW Washer
General Electric WWA8610SBLAA Washer
General Electric WWA8610SBLWW Washer
General Electric WWA8616MAL Washer
General Electric WWA8616RBL Washer
General Electric WWA8620MAL Washer
General Electric WWA8620RBL Washer
General Electric WWA8620SALAA Washer
General Electric WWA8620SALWW Washer
General Electric WWA8620SBLAA Washer
General Electric WWA8620SBLWW Washer
General Electric WWA8620SCLAA Washer
General Electric WWA8620SCLWW Washer
General Electric WWA8630SALAA Washer
General Electric WWA8630SALWW Washer
General Electric WWA8630SBLAA Washer
General Electric WWA8630SBLWW Washer
General Electric WWA8648MAL Washer
General Electric WWA8650SALAA Washer
General Electric WWA8650SALWW Washer
General Electric WWA8650SBLAA Washer
General Electric WWA8650SBLWW Washer
General Electric WWA8657MAL Washer
General Electric WWA8657RBL Washer
General Electric WWA8666RBL AUTOMATIC WASHER
General Electric WWA8689MAL Washer
General Electric WWA8689RBL AUTOMATIC WASHER
General Electric WWA8689RBLAA Washer
General Electric WWA8689RBLWW Washer
General Electric WWA8695SALAA Washer
General Electric WWA8695SALWW Washer
General Electric WWA8695SBLAA Washer
General Electric WWA8695SBLWW Washer
General Electric WWA8700LAL Washer
General Electric WWA8700LBL Washer
General Electric WWA8800MAL Washer
General Electric WWA8800RBL
General Electric WWA8800RBLAA Washer
General Electric WWA8800RBLWW Washer
General Electric WWA8806MAL Washer
General Electric WWA8808MAL Washer
General Electric WWA8810MAL Washer
General Electric WWA8810RBL Washer
General Electric WWA8816RBL Washer
General Electric WWA8819MAL Washer
General Electric WWA8827MAL Washer
General Electric WWA8829RBLWW Washer
General Electric WWA8836MAL Washer
General Electric WWA8837RBL Washer
General Electric WWA8849RBLWW Washer
General Electric WWA8850RBL
General Electric WWA8850RBLAA Washer
General Electric WWA8850RBLWW Washer
General Electric WWA8850SALAD Washer
General Electric WWA8850SALHA Washer
General Electric WWA8850SALWH Washer
General Electric WWA8857RBL Washer
General Electric WWA8858MAL Washer
General Electric WWA8866RBL Washer
General Electric WWA8869MAL Washer
General Electric WWA8876MAL Washer
General Electric WWA8879RBLWW Washer
General Electric WWA8887MAL Washer
General Electric WWA8887RBL Washer
General Electric WWA8890RBL AUTOMATIC WASHER
General Electric WWA8890RBLAA Washer
General Electric WWA8890RBLWW Washer
General Electric WWA8896RBL Washer
General Electric WWA8898MAL Washer
General Electric WWA8900SALAA Washer
General Electric WWA8900SALWW Washer
General Electric WWA8935SALAA Washer
General Electric WWA8935SALWW Washer
General Electric WWA8950SALAA Washer
General Electric WWA8950SALWW Washer
General Electric WWA8955SALAA Washer
General Electric WWA8955SALWW Washer
General Electric WWA8990SALAA Washer
  #2 (permalink)
Old 12-17-2009, 05:46 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
This is an older model, probably in the age of 15 to 20 years old. It was a very good machine for its day, but newer ones are bigger and better.
I would check the connections and the wiring. Also here is a site which will give you some trouble shooting ideas for your machine.
http://www.applianceaid.com/ge-os-wash.html
I would not recommend sinking a lot money into parts for it, and instead if you cannot get it going I suggest you purchas a good used or new top loading no frills washer.
__________________
  #3 (permalink)
Old 12-17-2009, 06:53 PM
Junior Member
Default
Thank you for taking the time to answer me. I think you may be right about connections. If I smack the back panel behind the dial it works fine. I'm going to check all the connections and go from there. Again, thank you!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
help how do you speciffically replace washer timer on Maytag washer stupid1 Washer Repair 5 07-04-2009 05:21 PM
is this model number washer a direct drive washer dandjwashington Washer Repair 2 05-01-2009 07:26 PM
Change Washer Lid Switch on Stacked Washer/Dryer scottcomputers Washer Repair 1 05-01-2009 10:16 AM
maytag washer/dyer combo washer no water lindavanzandt Washer Repair 0 11-30-2008 08:35 AM
