Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   GE Washer (http://forum.appliancepartspros.com/washer-repair/64236-ge-washer.html)
privilege42 12-15-2009 06:11 PM
GE Washer
I recently purchased a water inlet valve from you and everything was working fine until today. The washer fills, but will not go into the wash cycle. If I manually advance the dial to rinse it will start to spin and drain. I tried to turn the dial to wash mode in other cycles, but no luck.
sidfink43 12-17-2009 06:46 PM
This is an older model, probably in the age of 15 to 20 years old. It was a very good machine for its day, but newer ones are bigger and better.
I would check the connections and the wiring. Also here is a site which will give you some trouble shooting ideas for your machine.
http://www.applianceaid.com/ge-os-wash.html
I would not recommend sinking a lot money into parts for it, and instead if you cannot get it going I suggest you purchas a good used or new top loading no frills washer.
privilege42 12-17-2009 07:53 PM
Thank you for taking the time to answer me. I think you may be right about connections. If I smack the back panel behind the dial it works fine. I'm going to check all the connections and go from there. Again, thank you!
