Discuss
grinding noise in spin cycle
 in
Washer Repair
The noise sounds as if it coming from the water drain pump. How can I be sure that is the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » grinding noise in spin cycle
  #1 (permalink)
Old 12-15-2009, 11:51 AM
Junior Member
makuta13 is on a distinguished road
Default grinding noise in spin cycle
Model Number: pav2300aww   Brand: Maytag   Age: 5 - 10 years
The noise sounds as if it coming from the water drain pump. How can I be sure that is the problem?
Related Models
Maytag PAV2300AWW WASHER-TOP LOADING
Maytag PAV2360AWW WASHER-TOP LOADING
Admiral PAV2755AAW WASHER-TOP LOADING
Maytag PAV3000AWW WASHER-TOP LOADING
Maytag PAV3100AWW WASHER-TOP LOADING
Admiral PAV3200AAW WASHER-TOP LOADING
Admiral PAV3200AGW WASHER-TOP LOADING
Maytag PAV3200AWW WASHER-TOP LOADING
Maytag PAV3240AWW WASHER-TOP LOADING
Maytag PAV3250AWW WASHER-TOP LOADING
Admiral PAV3300AGW WASHER-TOP LOADING
Admiral PAV3300AKW WASHER-TOP LOADING
Maytag PAV3300AWW WASHER-TOP LOADING
Maytag PAV3360AWW WASHER-TOP LOADING
Admiral PAV3855AAW WASHER-TOP LOADING
Maytag PAV4960AWW WASHER-TOP LOADING
Maytag PAV5000AWQ WASHER-TOP LOADING
Maytag PAV5000AWW WASHER-TOP LOADING
Maytag PAV5057AWW WASHER-TOP LOADING
Maytag PAV5058AWW WASHER-TOP LOADING
Maytag PAV5157AWW WASHER-TOP LOADING
Maytag PAV5158AWW WASHER-TOP LOADING
Admiral PAVS234AWW WASHER-TOP LOADING
Admiral PAVS244AWW WASHER-TOP LOADING
Maytag PAVT134AWW WASHER-TOP LOADING
Maytag PAVT144AWW WASHER-TOP LOADING
Maytag PAVT234AWQ WASHER-TOP LOADING
Maytag PAVT234AWW WASHER-TOP LOADING
Maytag PAVT244AWQ WASHER-TOP LOADING
Maytag PAVT244AWW WASHER-TOP LOADING
Maytag PAVT344AWW WASHER-TOP LOADING
Maytag PAVT444AWW WASHER-TOP LOADING
Maytag PAVT454EWW WASHER-TOP LOADING
Maytag PAVT910AWW WASHER-TOP LOADING
Maytag PAVT915AWW WASHER-TOP LOADING
Maytag PAVT920AWW WASHER-TOP LOADING
Thermador PB30YS
General Electric PB750DN1BB ELECTRIC RANGE
General Electric PB750TN1WW ELECTRIC RANGE
General Electric PB900DP1BB ELECTRIC RANGE
General Electric PB900DP2BB ELECTRIC RANGE
General Electric PB900DP3BB ELECTRIC RANGE
General Electric PB900DP4BB ELECTRIC RANGE
General Electric PB900SP1SS ELECTRIC RANGE
General Electric PB900SP2SS ELECTRIC RANGE
General Electric PB900SP3SS ELECTRIC RANGE
General Electric PB900SP4SS ELECTRIC RANGE
General Electric PB900TP1WW ELECTRIC RANGE
General Electric PB900TP2WW ELECTRIC RANGE
General Electric PB900TP3WW ELECTRIC RANGE
General Electric PB900TP4WW ELECTRIC RANGE
General Electric PB909DP1BB ELECTRIC RANGE
General Electric PB909DP2BB ELECTRIC RANGE
General Electric PB909DP3BB ELECTRIC RANGE
General Electric PB909DP4BB ELECTRIC RANGE
General Electric PB909DP5BB ELECTRIC RANGE
General Electric PB909SP1SS ELECTRIC RANGE
General Electric PB909SP2SS ELECTRIC RANGE
General Electric PB909SP3SS ELECTRIC RANGE
General Electric PB909SP4SS ELECTRIC RANGE
General Electric PB909SP5SS ELECTRIC RANGE
General Electric PB909TP1WW ELECTRIC RANGE
General Electric PB909TP2WW ELECTRIC RANGE
General Electric PB909TP3WW ELECTRIC RANGE
General Electric PB909TP4WW ELECTRIC RANGE
General Electric PB909TP5WW ELECTRIC RANGE
General Electric PB909TR1CC ELECTRIC RANGE
General Electric PB909TR2CC ELECTRIC RANGE
General Electric PB910DP1BB ELECTRIC RANGE
General Electric PB910DP2BB ELECTRIC RANGE
General Electric PB910DP3BB ELECTRIC RANGE
General Electric PB910DP4BB ELECTRIC RANGE
General Electric PB910SP1SS ELECTRIC RANGE
General Electric PB910SP2SS ELECTRIC RANGE
General Electric PB910SP3SS ELECTRIC RANGE
General Electric PB910SP4SS ELECTRIC RANGE
General Electric PB910TP1CC ELECTRIC RANGE
General Electric PB910TP1WW ELECTRIC RANGE
General Electric PB910TP2CC ELECTRIC RANGE
General Electric PB910TP2WW ELECTRIC RANGE
General Electric PB910TP3CC ELECTRIC RANGE
General Electric PB910TP3WW ELECTRIC RANGE
General Electric PB910TP4CC ELECTRIC RANGE
General Electric PB910TP4WW ELECTRIC RANGE
General Electric PB920DP1BB ELECTRIC RANGE
General Electric PB920DP2BB ELECTRIC RANGE
General Electric PB920DP3BB ELECTRIC RANGE
General Electric PB920DP4BB ELECTRIC RANGE
General Electric PB920DP5BB ELECTRIC RANGE
General Electric PB920SP1SS ELECTRIC RANGE
General Electric PB920SP2SS ELECTRIC RANGE
General Electric PB920SP3SS ELECTRIC RANGE
General Electric PB920SP4SS ELECTRIC RANGE
General Electric PB920SP5SS ELECTRIC RANGE
General Electric PB920TP1WW ELECTRIC RANGE
General Electric PB920TP2WW ELECTRIC RANGE
General Electric PB920TP3WW ELECTRIC RANGE
General Electric PB920TP4WW ELECTRIC RANGE
General Electric PB920TP5WW ELECTRIC RANGE
General Electric PB969DP1BB ELECTRIC RANGE
General Electric PB969DP2BB ELECTRIC RANGE
General Electric PB969DP3BB ELECTRIC RANGE
General Electric PB969DP4BB ELECTRIC RANGE
General Electric PB969SP1SS ELECTRIC RANGE
General Electric PB969SP2SS ELECTRIC RANGE
General Electric PB969SP3SS ELECTRIC RANGE
General Electric PB969SP4SS ELECTRIC RANGE
General Electric PB970BM1BB ELECTRIC RANGE
General Electric PB970BM2BB ELECTRIC RANGE
General Electric PB970BM3BB ELECTRIC RANGE
General Electric PB970DP1BB ELECTRIC RANGE
General Electric PB970DP2BB ELECTRIC RANGE
General Electric PB970DP3BB ELECTRIC RANGE
General Electric PB970DP4BB ELECTRIC RANGE
General Electric PB970KM1CC ELECTRIC RANGE
General Electric PB970KM2CC ELECTRIC RANGE
General Electric PB970KM3CC ELECTRIC RANGE
General Electric PB970SM1SS ELECTRIC RANGE
General Electric PB970SM2SS ELECTRIC RANGE
General Electric PB970SM3SS ELECTRIC RANGE
  #2 (permalink)
Old 12-16-2009, 10:58 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
The main way we diagnose noises is to take off some cabinet pieces and listen to them and determine where they are coming from.
It is likely your pump is the problem, since Maytag re-designed it, and they typically do something like that because there is a problem with the old design. Here is a tech bulletin on the new pump.
http://www.servicematters.com/maytag...TDL-0106-B.pdf
You access the pump by removing the rear service panel.
You should also take off the front panel and listen to the machine to see if the noise is coming from any other source, and to check for leaks or any other water problem.
Inserting a screw driver or putty knife in the gap between the top and the front will releas clips that hold the top down. Flip it up and you can remove the front panel screws.
Here is the service manual for your machine.
http://www.servicematters.com/maytag...s/16023083.pdf
and here is the part
Part number: AP4373022
__________________
  #3 (permalink)
Old 02-12-2011, 05:10 PM
Junior Member
TPMichigan is on a distinguished road
Default EASY FIX after much searching!
I had this same problem! A terrible grinding noise during spin cycle and even sounding as if it would get caught-
After removing the front cover and running the spin cycle, I could hear and feel the noise and abnormal movement coming from the pump. I took out the three screws to remove the pump and found a quarter in there! Took it out, put it back together and ALL FIXED- no noise!
  #4 (permalink)
Old 02-12-2011, 05:14 PM
Senior Expert
APP Volunteer
Default
Great, thanks for sharing that with us, it will help a lot of folks.
__________________
  #5 (permalink)
Old 02-12-2011, 05:15 PM
Member
cammyj1967 is on a distinguished road
Default
remove the pump and turn it by hand. also check nothing is in it before ordering a new one.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
spin cycle makes grinding noise, no spin jgungho Washer Repair 1 12-24-2009 10:28 AM
Loud grinding noise when spin cycle starts jivko Washer Repair 1 11-07-2009 05:40 PM
Grinding noise when spin cycle stops cuba_pete Washer Repair 1 12-21-2008 08:42 PM
Grinding Noise After Spin Cycle eugene413 Washer Repair 1 12-11-2008 05:21 PM
Loud grinding noise in spin cycle flyrod45 Washer Repair 0 02-19-2008 01:39 PM
