Discuss
Kenmore fills then just hums
 in
Washer Repair
Hello. I have a Kenmore 80 series that will fill with water and then nothing. Something just hums from the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore fills then just hums
  #1 (permalink)
Old 12-15-2009, 08:03 AM
Junior Member
Robert and Beth is on a distinguished road
Default Kenmore fills then just hums
Model Number: 11020832991   Brand: Kenmore   Age: 5 - 10 years
Hello. I have a Kenmore 80 series that will fill with water and then nothing. Something just hums from the point it stops filling. I have replaced the motor with the tought it was bad. Checked the motor coupling and it is fine. I can turn the motor shat (at pump point) with a large wrench and the basket will spin, thus seeming as though the transmission and such is fine. The pump does not appear or act clogged as can use the pump to remove water by turn with my drill.
The last thing I can think of and read about is the timmer switch, however, I dont want to just start throwing money "chasing" parts. Can you tell me any thougths you may have..... Thank you in advance.
Robert
Related Models
Kenmore 11020832991 WASHER
Kenmore 11020842990 AUTOMATIC WASHER
Kenmore 11020842991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020852990 AUTOMATIC WASHER
Kenmore 11020852991 WASHER
Kenmore 11020854990 AUTOMATIC WASHER
Kenmore 11020854991 WASHER
Kenmore 11020857990 AUTOMATIC WASHER
Kenmore 11020862990 AUTOMATIC WASHER
Kenmore 11020862991 WASHER
Kenmore 11020872990 AUTOMATIC WASHER
Kenmore 11020872991 WASHER
Kenmore 11020882990 AUTOMATIC WASHER
Kenmore 11020882991 WASHER
Kenmore 11020892990 AUTOMATIC WASHER
Kenmore 11020892991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020894990 AUTOMATIC WASHER
Kenmore 11020894991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020897990 AUTOMATIC WASHER
Kenmore 11020901990 AUTOMATIC WASHER
Kenmore 11020901991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020902990 AUTOMATIC WASHER
Kenmore 11020902991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020904990 AUTOMATIC WASHER
Kenmore 11020904991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020907990 AUTOMATIC WASHER
Kenmore 11020907991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020912990 AUTOMATIC WASHER
Kenmore 11020912991 WASHER
Kenmore 11020922990 AUTOMATIC WASHER
Kenmore 11020922991 WASHER
Kenmore 11020924990 AUTOMATIC WASHER
Kenmore 11020924991 WASHER
Kenmore 11020927990 AUTOMATIC WASHER
Kenmore 11020932990 AUTOMATIC WASHER
Kenmore 11020932991 AUTOMATIC WASHER
Kenmore 11020932992 AUTOMATIC WASHER
Kenmore 11020932993 WASHER
Kenmore 11020932994 WASHER
Kenmore 11020936990 AUTOMATIC WASHER
Kenmore 11020936991 AUTOMATIC WASHER
Kenmore 11020936992 AUTOMATIC WASHER
Kenmore 11020936993 WASHER
Kenmore 11020936994 WASHER
Kenmore 11020942990 AUTOMATIC WASHER
Kenmore 11020942991 AUTOMATIC WASHER
Kenmore 11020942992 AUTOMATIC WASHER
Kenmore 11020942993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020942994 WASHER
Kenmore 11020952990 AUTOMATIC WASHER
Kenmore 11020952991 AUTOMATIC WASHER
Kenmore 11020952992 AUTOMATIC WASHER
Kenmore 11020952993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020952994 WASHER
Kenmore 11020954992 AUTOMATIC WASHER
Kenmore 11020954993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020954994 WASHER
Kenmore 11020956990 AUTOMATIC WASHER
Kenmore 11020956991 AUTOMATIC WASHER
Kenmore 11020956992 AUTOMATIC WASHER
Kenmore 11020956993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020956994 WASHER
Kenmore 11020957990 AUTOMATIC WASHER
Kenmore 11020957991 AUTOMATIC WASHER
Kenmore 11020957992 AUTOMATIC WASHER
Kenmore 11020972990 WASHER
Kenmore 11020972991 WASHER
Kenmore 11020972992 WASHER
Kenmore 11020972993 WASHER
Kenmore 11020982990 WASHER
Kenmore 11020982991 WASHER
Kenmore 11020982992 WASHER
Kenmore 11020982993 WASHER
Kenmore 11020992990 WASHER
Kenmore 11020992991 WASHER
Kenmore 11020992992 WASHER
Kenmore 11020992993 WASHER
Kenmore 11020994991 WASHER
Kenmore 11020994992 WASHER
Kenmore 11020994993 WASHER
Kenmore 11020996991 WASHER
Kenmore 11020996992 WASHER
Kenmore 11020996993 WASHER
Kenmore 11020997990 WASHER
Kenmore 11020997991 WASHER
Kenmore 11020997992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021102010 AUTOMATIC WASHER
Kenmore 11021102011 AUTOMATIC WASHER
Kenmore 11021112010 AUTOMATIC WASHER
Kenmore 11021112011 AUTOMATIC WASHER
Kenmore 11021182010 AUTOMATIC WASHER
Kenmore 11021182011 AUTOMATIC WASHER
Kenmore 11021202010 AUTOMATIC WASHER
Kenmore 11021202011 AUTOMATIC WASHER
Kenmore 11021252110 AUTOMATIC WASHER
Kenmore 11021292010 AUTOMATIC WASHER
Kenmore 11021292011 AUTOMATIC WASHER
Kenmore 11021302010 AUTOMATIC WASHER
Kenmore 11021302011 AUTOMATIC WASHER
Kenmore 11021352110 AUTOMATIC WASHER
Kenmore 11021392010 AUTOMATIC WASHER
Kenmore 11021392011 AUTOMATIC WASHER
Kenmore 11021392012 AUTOMATIC WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
  #2 (permalink)
Old 12-16-2009, 06:50 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Hi Robert and Beth
This is kind of a mystery. I am assuming that your problem exists during both agitate, drain and spin in all cycles.
I suggest you take the motor off and leave it connected and put the machine in spin (you will have to by pass the lid switch) and see if the motor turns. If everything checks out I am leaning towards the capacitor. It is very unusual that they fail, but given your symptoms and what you have already done that seems a logical place to go. If that is not the problem wiring to the motor, the motor connection or the timer would be suspects.
I agree that just changing out parts is not something you want to do, that may be what you have to do in this case.
__________________
  #3 (permalink)
Old 12-16-2009, 07:10 AM
Junior Member
Default
Thank you. I actually did change out the capacitor last night when I got home, all is working fine again and Beth is happy.
Thank you for your help.
  #4 (permalink)
Old 12-16-2009, 07:40 AM
Senior Expert
APP Volunteer
Default
Super, glad that fixed it and thanks for the update.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dishwasher fills, then hums doesn't spin eflagg03 Dishwasher Repair 4 08-30-2010 08:54 AM
Water fills but then it just hums Jambo Dishwasher Repair 5 07-27-2009 08:20 PM
Dishwasher fills with water then hums -- no wash k_kodiak Dishwasher Repair 2 07-14-2009 03:47 PM
Kenmore Microwave Hums - No Heat bobmcg Microwave Repair 0 12-06-2008 04:15 PM
Amana fills with H20 then motor hums and smokes jpstelly Washer Repair 3 01-28-2008 07:59 PM
