Discuss
Whirpool clothes washer not draining
 in
Washer Repair
The washer fills and agitates but will not drain. Multiple cycle settings (perm press, handwash, etc.) all have the same
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirpool clothes washer not draining
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-18-2008, 08:05 AM
handypete handypete is offline
Junior Member
handypete is on a distinguished road
Question Whirpool clothes washer not draining
Model Number: LSR7233DQ0   Brand: Whirlpool   Age: More than 10 years
The washer fills and agitates but will not drain. Multiple cycle settings (perm press, handwash, etc.) all have the same problem. I suspect the pump - but don't want to replace if it is something else. Is there an easy test for pump failure?
Thanks for any suggestions.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-18-2008, 04:12 PM
roycreamer roycreamer is offline
Expert
APP Volunteer
roycreamer is on a distinguished road
Default
if it spins, you probably have something stuck in the pump, or the hose that comes from the tub to the pump.
__________________
roy
the appliance whisperer
  #3 (permalink)
Old 03-19-2008, 10:47 AM
Junior Member
Default
Thank you for the suggestion. I'll check that.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer is not draining MMBell Washer Repair 2 02-25-2008 10:56 AM
whirpool washer Bennie Washer Repair 1 02-23-2008 09:10 AM
Washer fills but just keeps draining jeepman Washer Repair 2 02-22-2008 07:48 PM
Whirpool Duet Washer mansoor ali Washer Repair 1 12-16-2007 07:45 PM
Need clean cloths, whirpool washer smurzynski Washer Repair 1 08-06-2007 04:50 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
