Discuss
Motor Coupling Needed With New Pump?
 in
Washer Repair
My washer pump is leaking and I plan to order a new one. How do I determine if a new
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Motor Coupling Needed With New Pump?
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-17-2008, 08:34 AM
tonto97@scrtc.com tonto97@scrtc.com is offline
Junior Member
tonto97@scrtc.com is on a distinguished road
Default Motor Coupling Needed With New Pump?
Model Number: LSR8233EQ0   Brand: Whirlpool   Age: 5 - 10 years
My washer pump is leaking and I plan to order a new one. How do I determine if a new pump-motor coupling is also needed?
Thanks,
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-17-2008, 02:00 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Normally, I would just pull out the motor and check the coupling for wear. You might also find the pump rusted to the motor shaft. I usually pound it off with a hammer. When off, check the motor bushings for wear.
__________________
  #3 (permalink)
Old 03-17-2008, 03:42 PM
Matt S Matt S is offline
Senior Expert
APP Volunteer
Matt S is on a distinguished road
Default
Good call.
If the motor shaft is rusted, you can grab the motor shaft with piers and move the pliers back and forth. That will break the rust off the motor shaft. Normally the pump comes off fine, though.
The coupler is probably OK. But, hey, if you already have the machine apart, it is not a bad time to replace it if you do not mind spending a few extra dollars.
Matt
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
motor coupling repair castled Washer Repair 2 03-16-2008 09:58 AM
Changing motor coupling on washer abbylou22 Washer Repair 2 01-21-2008 06:39 PM
new motor coupling doesn't seem to fit wdunkin Washer Repair 1 12-29-2007 08:33 AM
dishwasher instructions to replace complete motor and pump assembly needed Nancy Ramsey Dishwasher Repair 0 10-25-2007 12:22 PM
Motor Coupling Removal steved Washer Repair 2 09-29-2007 03:19 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
