The washer lid switch unexpectedly stopped functioning. Keeping the lid open and depressing the switch manually, using a screw driver with insulated handle, allowed the machine to go through its cycle.
As a nonogenarian would wish to avoid having to pull the washer/dryer unit from its niche on a concrete floor to a carpeted area in order to remove the housing and replace a switch that might not need replacing. The plastic tip, attached to the lid, seems to be in its original size. Would welcome any and every suggestion. Am the only user and operate for the time being with a teaspoon handle, taped at the handle end with the max. thickness allowed by the slot in the housing, the spoon-end will prevent it from disapearing during the machine spin vibration.
Thanks in advance for the most economical solution.
I understand your situtation, but this is a safety issue and you cannot be certain that at some time in the future someone else will need to use the machine. It is important that the lid switch work, because serious injury can result if someone sticks a hand in a spinning washer.
I strongly recommend you replace the lid switch.
Thank you for the quick response and good advice. As is, there is no risk to anyone since the machine will not spin, lid open or closed.
The switch is operational, it seems the plastic pointer fails to make contact. So am uncertain how replacing switch will solve the malfunction.
Have a good weekend,
20091212 19:10 UTC
If the plastic pointer is ok, what has probably happened is the tab it strikes has partially broken. This is why it will work when you insert the screw driver. This is a common enough occurence and if you replace the lid switch that will fix things.
I cannot recommend that you do this, but if you are really determined to operate the machine without replacing the lid switch you can by pass it. To do this you do not have to move anything or need special tools.
Take out the two screws that hold the console to the top. They may be in the front on the console, on the back or under trim pieces. Flip up the console, unhook the plastic lid switch connector and insert a solid insulated wire, with the ends exposed into the two outer holes on the connector coming from the console. Tape the by pass in place, put the console back in place and you are set to go.
If you do this I would write on a piece of paper the words in big bold print, LID SWITCH DISABLED - DO NOT INSERT ANYTHING DURING OPERRATION and paste it on the machine.
Much obliged for suggestion, will follow, will also order replacement switch and when I have a young stallion visiting, will ask him for a hand to move washer/dryer combo, so switch can be replaced.
It's hard to believe, my (not so) trusty electrician suggested replace machine, it seems bankers and Wall Street aren't the only one obsessed with greed.
Joyous Holidays for you and yours, a grateful nonogenarian. 20091213 20:03 UTC
Ok, good. I was somewhat asleep at the switch here and did not recognize that you had the stacked washer dryer combo. The solution is the same, but you will get into it slightly differently, and here is the service manual to show you how. https://secured.whirlpoo.../$FILE/L-56_4314124A.pdf
Thank you very much indeed.
kurt 20091214 17:15 UTC
