i washed a rug while it was washing it made a squiling noise then finished the rug then i put my sheets into wash...it started the cycle then just stoped and wont drain or anything...it had a burning rubber smell to it????
Sounds like material from the rug has jammed in the tub. Rugs and home washers really do not like each other.
You need to remove the inner tub and clean it out. Insert a screw driver in the gap between the top and front near the edges to release clips, which will allow the top to flip back. Take off the agitator by removing the dispensor cup and taking out the screw and then lifting out the agitator. Take off the ring around the tub, and then take out the screws in the tub and it will lift out.
