washer making noisy/ I need help
Washer Repair
I have frontload washer make loud noise when It spin. I just replaced new vibration shock absorber but not making
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer making noisy/ I need help
  #1 (permalink)
Old 12-10-2009, 01:10 PM
Junior Member
kbl88 is on a distinguished road
Default washer making noisy/ I need help
Model Number: FTF630ASO   Brand: Frigidaire   Age: 1 - 5 years
I have frontload washer make loud noise when It spin. I just replaced new vibration shock absorber but not making better. Thanks in advance
Related Models
Frigidaire FTFB2940FE0 Frigidaire/washer
Frigidaire FTFB2940FE1 WASHER
Frigidaire FTFB4000FS0 Frigidaire/washer
Frigidaire FTFB4000FS1 Frigidaire/washer
Frigidaire FTFB4000GS0 Frigidaire/washer
Frigidaire FTFB4000GS1 WASHER
Frigidaire FTR630AS0 Frtld Washer - Frigidaire
Frigidaire FTW3011KW0 WASHER
Frigidaire FTW3014KW0 WASHER
Frigidaire FU017RRW1 Wwh(v2) / Upright Freezer
Frigidaire FU018TRW1 Wwh(v3) / Upright Freezer
Frigidaire FU019ARW5 Wwh(v3) / Upright Freezer
Frigidaire FU054ERD1 Wwh(v1) / Upright Freezer
Frigidaire FU054ERD2 Wwh(v2) / Upright Freezer
Frigidaire FU054ERD3 Wwh(v3) / Upright Freezer
Frigidaire FU054ERW1 Wwh(v4) / Upright Freezer
Frigidaire FU054ERW2 Wwh(v5) / Upright Freezer
Frigidaire FU100JRW1 Wwh(v1) / Upright Freezer
Frigidaire FU100JRW2 Wwh(v2) / Upright Freezer
Frigidaire FU100JRW3 Wwh(v3) / Upright Freezer
Frigidaire FU100JRW4 Wwh(v1) / Upright Freezer
Frigidaire FU100JRW5 Wwh(v1) / Upright Freezer
Frigidaire FU100LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU100LRW2 Wwh(v2) / Upright Freezer
Frigidaire FU100LRW3 Wwh(v3) / Upright Freezer
Frigidaire FU100LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU100LRW5 Wwh(v2) / Upright Freezer
Frigidaire FU134ERW1 Wwh(v1) / Upright Freezer
Frigidaire FU134ERW2 Wwh(v2) / Upright Freezer
Frigidaire FU134ERW3 Wwh(v3) / Upright Freezer
Frigidaire FU134ERW4 Wwh(v4) / Upright Freezer
Frigidaire FU134JRW1 Wwh(v1) / Upright Freezer
Frigidaire FU134JRW2 Wwh(v2) / Upright Freezer
Frigidaire FU134JRW3 Wwh(v3) / Upright Freezer
Frigidaire FU134JRW4 Wwh(v2) / Upright Freezer
Frigidaire FU134JRW5 Wwh(v1) / Upright Freezer
Frigidaire FU134LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU134LRW2 Wwh(v2) / Upright Freezer
Frigidaire FU134LRW3 Wwh(v3) / Upright Freezer
Frigidaire FU134LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU134LRW5 Wwh(v1) / Upright Freezer
Frigidaire FU161ERW1 Wwh(v1) / Upright Freezer
Frigidaire FU161ERW2 Wwh(v2) / Upright Freezer
Frigidaire FU161ERW3 Wwh(v3) / Upright Freezer
Frigidaire FU161ERW4 Wwh(v4) / Upright Freezer
Frigidaire FU161ERW5 Wwh(v5) / Upright Freezer
Frigidaire FU161ERW6 Wwh(v6) / Upright Freezer
Frigidaire FU161JRW1 Wwh(v0) / Upright Freezer
Frigidaire FU161JRW2 Wwh(v0) / Upright Freezer
Frigidaire FU161JRW3 Wwh(v3) / Upright Freezer
Frigidaire FU161LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU161LRW2 Wwh(v2) / Upright Freezer
Frigidaire FU161LRW3 Wwh(v1) / Upright Freezer
Frigidaire FU161LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU161LRW5 Wwh(v1) / Upright Freezer
Frigidaire FU161LRW6 Wwh(v1) / Upright Freezer
Frigidaire FU166ERW1 Wwh(v7) / Upright Freezer
Frigidaire FU166ERW2 Wwh(v8) / Upright Freezer
Frigidaire FU166ERW3 Wwh(v9) / Upright Freezer
Frigidaire FU166ERW4 Wwh(v10) / Upright Freezer
Frigidaire FU166HRD1 Wwh(v1) / Upright Freezer
Frigidaire FU166HRD2 Wwh(v2) / Upright Freezer
Frigidaire FU166HRW1 Wwh(v3) / Upright Freezer
Frigidaire FU166HRW2 Wwh(v4) / Upright Freezer
Frigidaire FU166HRW3 Wwh(v5) / Upright Freezer
Frigidaire FU168JRD1 Wwh(v1) / Upright Freezer
Frigidaire FU168JRD2 Wwh(v2) / Upright Freezer
Frigidaire FU168JRD3 Wwh(v1) / Upright Freezer
Frigidaire FU168JRW1 Wwh(v3) / Upright Freezer
Frigidaire FU168JRW2 Wwh(v4) / Upright Freezer
Frigidaire FU168JRW3 Wwh(v2) / Upright Freezer
Frigidaire FU168LRW1 Wwh(v2) / Upright Freezer
Frigidaire FU168LRW2 Wwh(v4) / Upright Freezer
Frigidaire FU169ERD1 Wwh(v1) / Upright Freezer
Frigidaire FU169ERD2 Wwh(v2) / Upright Freezer
Frigidaire FU169ERW1 Wwh(v3) / Upright Freezer
Frigidaire FU169ERW2 Wwh(v4) / Upright Freezer
Frigidaire FU169JRD1 Wwh(v1) / Upright Freezer
Frigidaire FU169JRD2 Wwh(v2) / Upright Freezer
Frigidaire FU169JRD3 Wwh(v4) / Upright Freezer
Frigidaire FU169JRW1 Wwh(v2) / Upright Freezer
Frigidaire FU169JRW2 Wwh(v1) / Upright Freezer
Frigidaire FU169JRW3 Wwh(v3) / Upright Freezer
Frigidaire FU169LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU169LRW2 Wwh(v1) / Upright Freezer
Frigidaire FU169LRW3 Wwh(v2) / Upright Freezer
Frigidaire FU169LRW4 Wwh(v3) / Upright Freezer
Frigidaire FU169LRW5 Wwh(v1) / Upright Freezer
Frigidaire FU169LRW6 Wwh(v1) / Upright Freezer
Frigidaire FU196ERW1 Wwh(v1) / Upright Freezer
Frigidaire FU196ERW2 Wwh(v2) / Upright Freezer
Frigidaire FU196ERW3 Wwh(v3) / Upright Freezer
Frigidaire FU196JRW1 Wwh(v0) / Upright Freezer
Frigidaire FU196JRW2 Wwh(v4) / Upright Freezer
Frigidaire FU196JRW3 Wwh(v1) / Upright Freezer
Frigidaire FU196LRW1 Wwh(v1) / Upright Freezer
  #2 (permalink)
Old 12-11-2009, 02:03 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
This is very common with this model. It is likely the rear bearing is failing. You can listen to it and if the sound comes from the rear, that is what it is.
Unfortunately, it is not a repairable item, you have to replace the back half that contains the bearing. Since it is an expensive repair I would advise running the machine until you can no longer stand the noise, then getting a new one.
Sorry not to have better news.
  #3 (permalink)
Old 12-11-2009, 02:42 PM
Junior Member
thanks fot your help. today I just disassembly outer tub and there is the shaft attached to the spider ( 3 wings ) likely 3 arms bolted to inner tub. and 3 arms were broken off , so the shaft is not holding the inner tub. actualy I look in part ( diagram number 4 ( wshr tub, motor) the part AP2107258 is $243.56 + shipping , I dont know what should I do right now . thanks again
  #4 (permalink)
Old 12-12-2009, 02:37 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
You probably also have bad tub bearings, makes the repair too expensive.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
noisy washer william clegg Washer Repair 1 01-14-2010 06:17 PM
noisy washer william clegg Washer Repair 1 01-11-2010 11:58 AM
very noisy washer Eric Nelson Washer Repair 3 06-27-2009 03:00 PM
washer noisy shotgun58 Washer Repair 2 01-19-2009 08:01 AM
noisy washer terimanx Washer Repair 0 07-04-2008 10:11 AM
