Discuss
Maytag won't agitate & skips other cycles
 in
Washer Repair
Maytag washer fills, sits and at the very end of timer, spins and empties the washer. It did agitate once
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag won't agitate & skips other cycles
  #1 (permalink)
Old 12-10-2009, 10:34 AM
Junior Member
kovachjc is on a distinguished road
Default Maytag won't agitate & skips other cycles
Model Number: LAT9235AAE   Brand: Maytag   Age: 1 - 5 years
Maytag washer fills, sits and at the very end of timer, spins and empties the washer. It did agitate once but stll skipped a few cycles.
The timer motor is working and advancing. I'm assuming that it's ok. How can I check the drive motor and can it still be the motor even though it does spin at the end? Thanks.
Related Models
Maytag LAT9235AAE WASHER-TOP LOADING
Maytag LAT9235AAM WASHER-TOP LOADING
Maytag LAT9280AAL WASHER-TOP LOADING
Maytag LAT9280AAW WASHER-TOP LOADING
Maytag LAT9280ABL WASHER-TOP LOADING
Maytag LAT9280ABW WASHER-TOP LOADING
Maytag LAT9300AAL WASHER-TOP LOADING
Maytag LAT9300AAW WASHER-TOP LOADING
Maytag LAT9300ABL WASHER-TOP LOADING
Maytag LAT9300ABW WASHER-TOP LOADING
Maytag LAT9304AAE WASHER-TOP LOADING
Maytag LAT9304AAL WASHER-TOP LOADING
Maytag LAT9304AAM WASHER-TOP LOADING
Maytag LAT9304ABE WASHER-TOP LOADING
Admiral LAT9304AGE WASHER-TOP LOADING
Admiral LAT9304AGL WASHER-TOP LOADING
Admiral LAT9304AGM WASHER-TOP LOADING
Admiral LAT9304BGE WASHER-TOP LOADING
Maytag LAT9304DAL WASHER-TOP LOADING
Maytag LAT9304DAM WASHER-TOP LOADING
Admiral LAT9304EGE WASHER-TOP LOADING
Admiral LAT9304GGE WASHER-TOP LOADING
Maytag LAT9306AAE WASHER-TOP LOADING
Maytag LAT9306AAM WASHER-TOP LOADING
Maytag LAT9306ABE WASHER-TOP LOADING
Admiral LAT9306AGE WASHER-TOP LOADING
Admiral LAT9306AKM WASHER-TOP LOADING
Admiral LAT9306AKQ WASHER-TOP LOADING
Admiral LAT9306BGE WASHER-TOP LOADING
Admiral LAT9306DAM WASHER-TOP LOADING
Admiral LAT9306DAQ WASHER-TOP LOADING
Admiral LAT9306EGE WASHER-TOP LOADING
Admiral LAT9306GGE WASHER-TOP LOADING
Maytag LAT9314AAE WASHER-TOP LOADING
Maytag LAT9314AAL WASHER-TOP LOADING
Maytag LAT9314AAM WASHER-TOP LOADING
Maytag LAT9314ABE WASHER-TOP LOADING
Maytag LAT9316AAE WASHER-TOP LOADING
Maytag LAT9316AAM WASHER-TOP LOADING
Maytag LAT9316ABE WASHER-TOP LOADING
Maytag LAT9316ABM WASHER-TOP LOADING
Maytag LAT9334AAE WASHER-TOP LOADING
Maytag LAT9334AAL WASHER-TOP LOADING
Maytag LAT9334AAM WASHER-TOP LOADING
Maytag LAT9334ABE WASHER-TOP LOADING
Maytag LAT9356AAE WASHER-TOP LOADING
Maytag LAT9356AAM WASHER-TOP LOADING
Maytag LAT9356AAQ WASHER-TOP LOADING
Maytag LAT9356ABE WASHER-TOP LOADING
Maytag LAT9356ABM WASHER-TOP LOADING
Maytag LAT9357AAE WASHER-TOP LOADING
Maytag LAT9357AAM WASHER-TOP LOADING
Maytag LAT9357AAQ WASHER-TOP LOADING
Maytag LAT9360AAE WASHER-TOP LOADING
Maytag LAT9390AAE WASHER-TOP LOADING
Maytag LAT9400AAE WASHER-TOP LOADING
Maytag LAT9400AAL WASHER-TOP LOADING
Maytag LAT9400AAW WASHER-TOP LOADING
Maytag LAT9400ABE WASHER-TOP LOADING
Maytag LAT9400ABL WASHER-TOP LOADING
Maytag LAT9400ABW WASHER-TOP LOADING
Maytag LAT9400AGL WASHER-TOP LOADING
Maytag LAT9400AGW WASHER-TOP LOADING
Maytag LAT9400DAL WASHER-TOP LOADING
Maytag LAT9400DAW WASHER-TOP LOADING
Maytag LAT9406AAE WASHER-TOP LOADING
Maytag LAT9406AAM WASHER-TOP LOADING
Maytag LAT9406ABE WASHER-TOP LOADING
Maytag LAT9416AAE WASHER-TOP LOADING
Maytag LAT9416AAM WASHER-TOP LOADING
Maytag LAT9416AAQ WASHER-TOP LOADING
Maytag LAT9420AAE WASHER-TOP LOADING
Maytag LAT9457AAE WASHER-TOP LOADING
Maytag LAT9457AAM WASHER-TOP LOADING
Maytag LAT9457AAQ WASHER-TOP LOADING
Maytag LAT9457BAE WASHER-TOP LOADING
Maytag LAT9520AAE WASHER-TOP LOADING
Maytag LAT9520AAQ WASHER-TOP LOADING
Maytag LAT9557AAE WASHER-TOP LOADING
Maytag LAT9557AAQ WASHER-TOP LOADING
Maytag LAT9593AAL WASHER-TOP LOADING
Maytag LAT9593AAW WASHER-TOP LOADING
Maytag LAT9593ABL WASHER-TOP LOADING
Maytag LAT9593ABW WASHER-TOP LOADING
Maytag LAT9600AAL WASHER-TOP LOADING
Maytag LAT9600AAW WASHER-TOP LOADING
Maytag LAT9600ABL WASHER-TOP LOADING
Maytag LAT9600ABW WASHER-TOP LOADING
Maytag LAT9604AAE WASHER-TOP LOADING
Maytag LAT9604AAL WASHER-TOP LOADING
Maytag LAT9604AAM WASHER-TOP LOADING
Maytag LAT9604ABE WASHER-TOP LOADING
Maytag LAT9605AAE WASHER-TOP LOADING
Maytag LAT9605AAM WASHER-TOP LOADING
Maytag LAT9606AAE WASHER-TOP LOADING
Maytag LAT9606AAM WASHER-TOP LOADING
Maytag LAT9606ABE WASHER-TOP LOADING
Maytag LAT9606ABM WASHER-TOP LOADING
Admiral LAT9606AGE WASHER-TOP LOADING
Admiral LAT9606BGE WASHER-TOP LOADING
Admiral LAT9606GGE WASHER-TOP LOADING
Maytag LAT9614AAE WASHER-TOP LOADING
Maytag LAT9614AAL WASHER-TOP LOADING
Maytag LAT9614AAM WASHER-TOP LOADING
Maytag LAT9615AAE WASHER-TOP LOADING
Maytag LAT9615AAM WASHER-TOP LOADING
Maytag LAT9616AAE WASHER-TOP LOADING
Maytag LAT9616AAM WASHER-TOP LOADING
Maytag LAT9634AAE WASHER-TOP LOADING
Maytag LAT9634AAL WASHER-TOP LOADING
Maytag LAT9634AAM WASHER-TOP LOADING
Maytag LAT9634ABE WASHER-TOP LOADING
Maytag LAT9635AAE WASHER-TOP LOADING
Maytag LAT9635AAM WASHER-TOP LOADING
Maytag LAT9700AAL WASHER-TOP LOADING
Maytag LAT9700AAW WASHER-TOP LOADING
Maytag LAT9700ABL WASHER-TOP LOADING
Maytag LAT9700ABW WASHER-TOP LOADING
Maytag LAT9700DAL WASHER-TOP LOADING
Maytag LAT9700DAW WASHER-TOP LOADING
  #2 (permalink)
Old 12-11-2009, 01:47 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Although this service manual does not list your model number, it should be good for your model.
It will show you how to check the motor, but since it spins I think the problem is in the timer. See if the motor will run with the belt off when it is supposed to agitate. If not, think about replacing the timer.
http://www.servicematters.com/maytag...(16001145).pdf
__________________
  #3 (permalink)
Old 12-12-2009, 10:49 AM
Junior Member
Default
Thanks Sidfink43. I checked the motor as the print you sent showed and it's ok. I had assumed the timer was good as the timer motor worked and a continuity test showed ok, or so I thought. I'll buy a timer Monday. Thanks again.
  #4 (permalink)
Old 12-12-2009, 01:39 PM
Senior Expert
APP Volunteer
Default
Great, let us know how it works out.
__________________
  #5 (permalink)
Old 12-14-2009, 09:19 AM
Junior Member
Default
I ordered the timer online today from AppliancePartsPros so I'll let you know as soon as I get it up and running. Thanks again.
  #6 (permalink)
Old 12-14-2009, 09:45 AM
Junior Member
porsche911 is on a distinguished road
Default I had the same problem. I am interested in a reply..
I also have had the same problem with mine I am interested in the print.
  #7 (permalink)
Old 12-15-2009, 06:37 AM
Junior Member
Default
The print is in the manual at the blue link in the first reply.
  #8 (permalink)
Old 12-16-2009, 03:18 PM
Junior Member
Default
The timer came today and I installed it. As soon as I plugged the washer in it blew the fuse in the main panel. The timer looked the same other than it uses a different knob. I reinstalled the old timer to see if the fuse would blow again but it didn't. Upon examination I see that the timer motors and the connection for the harness are wired differently. The old timer is #M-520 and the new is #M-520-3. Hopefully ApplianceParts Pros will exchange it.
  #9 (permalink)
Old 12-16-2009, 04:31 PM
Senior Expert
APP Volunteer
Default
Well, sorry that happened.
We are not part of APP but my experience is that they are a very good company and I feel certain they will get you the right part.
There are a lot of variations in your model, so be sure and give them your serial number when you re-order/return so they can get it right.
__________________
  #10 (permalink)
Old 12-17-2009, 07:01 AM
Junior Member
Default
The customer service lady checked both my model and serial numbers and said it should be the correct timer. Besides the shaft where the knob goes being different and the internal wiring and the #3 added, it also is marked Magic Chef instead of Maytag. I realize that they are all one now but somebody made a change somehow. She's supposed to email me back after talking to the research people.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool won't fill w/ Water, skips to agitate/wash cycle. jeshurun41 Washer Repair 3 12-27-2009 04:29 AM
Maytag 300 Quite Series Cycles Off and ON kenspringtx Dishwasher Repair 11 11-02-2009 03:01 PM
Maytag A107 Series 01 does not oscillate, skips to next cycle Peretz Washer Repair 1 10-13-2009 02:36 PM
Skips final spin on certain cycles Tim M Washer Repair 1 08-17-2009 02:35 PM
Kenmore washer won't spin, agitate, or go through cycles asnapp Washer Repair 10 08-26-2008 06:53 PM
