| » Wrong Tub Repair Kit? |
Model Number: Lat9406AAE Brand: Maytag Age: More than 10 years
Ordered a Tub Repair Kit for this washer and have it all apart. The Tub Bearing will not fit over the sleeve on the power unit. Is it possible that I have the wrong tub bearing? Factory part number 204013 on the box. Am I missing something? Is there a sleeve on the power unit that comes off. Looks like it is all one piece on the power unit and nothing comes off.
Thanks, Rick Moore Ads By Google Related Models |
As far as I know you have the right part. On the transmission there is a sleeve that you must take off. Almost always I have to break it to get it off. A new sleeve comes with the bearing. There is a picture on this page that shows the sleeve I am talking about. Maytag Tub Seal Replacement
Here is what comes up when I cross reference the part number you supplied
Part number: AP4372971 Click on the above picture to see more views of it. This may help http://www.servicematters.com/maytag_library/docs/16010373%20(16001145).pdf I cannot say if you have the correct part but it is correct just by looking up your model number. You will have to call or email the parts people at AppliancePartsPros, if ordered from them. Have your serial number handy and they may be able to look up if there has been a series change
__________________
One more thing if you find that you have the right part (if it looks like the one in the picture above you do) and you have already removed the sleeve. But it still won’t go on you may have to clean the transmission shaft where the new sleeve goes on. Just use emery cloth to sand it a little.
Thanks all. I was able to get the sleeve off the power unit. It was on there pretty good and like you said had to break it to get it off. All back together and working good with no more leaks. Two more questions. The tub seems to vibrate a bit more then it used to on spin. Also, one of the clips on the top broke when opening up the front. Is there a part number and some kind of diagram to show how those things clip back in on the top front?
You guys are great, Thanks, Rick |
Is this the clip you are talking about? Part Details - WHIRLPOOL Fastener, spring, part number: AP4028417 If so you can order it here.
As for the fact that the tub vibrates more may be due to the fact that the spin basket is not aligned. Take the top and agitator back off. Then loosen the big nut that holds the spin basket in. Then make sure the gap between the tub and the spin basket is the same all the way around. If you have trouble getting it aligned you may loosen the nut and put the washer in spin. Let it spin with the nut loose (not compleatlly loose) and most of the time it will strighten itself out. Then tighten the nut back. Hope this helps!! |
Applianceman,
Yes ,thats the clip I'm looking for. I'll order them. I bet I'm not the first person to break these clips taking of the front panel. I'll try the loosening the bolt on the spin backet and see if it corrects the vibration. Thanks, Rick Quote:
| Display Modes | |
| what's wrong | AARON baseball | Oven Repair (including Ranges and Cooktops) | 1 | 12-02-2009 02:34 PM |
| What is wrong? | kctso | Washer Repair | 0 | 09-18-2009 03:17 PM |
| How do I check the defrost timer, heater, and thermostat and repair whats wrong | elgem3 | Refrigerator & Freezer Repair | 1 | 10-26-2008 04:36 PM |
| what's wrong? | fairull | Oven Repair (including Ranges and Cooktops) | 1 | 12-16-2007 04:31 PM |
