| » clicking at spin cycle |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: lwa30aw Brand: Amana Age: 5 - 10 years
i have a clicking sound when the washer trys to engage spin cycle. it trashed the belt so i put on a new one and the new one chatters bad when the belt reverses for the spin cycle. thanks for your help
ok, perhaps a little more info will help. i have removed the brake shoes and that did not help. the pulley will not engage when the belt changes direction. any ideas on what i should replace? can i check a clutch plate or springs or something in that assembly to see if thats broke?
Have never worked on this washer, but you can check it out at web site
www.applianceaid.com They say you either have a bad tranny pulley or worn helix and washers above the pulley. They say to pull the bolt and pulley off and add some washers, then assemble and turn the pulley in the spin direction, then the pulley will ride up the helix and engage the clutch to turn the basket. Please post results.
__________________
| Display Modes | |
| Washer will not spin during spin cycle | Nathaniel | Washer Repair | 4 | 01-30-2008 06:35 AM |
| Final spin cycle doesn't spin | gr8fulbear@yahoo.com | Washer Repair | 9 | 01-30-2008 04:01 AM |
| Runs rinse cycle all the way through the spin cycle | hebirdseye | Washer Repair | 1 | 01-20-2008 05:10 PM |
| washer won't spin in final spin cycle | amie48 | Washer Repair | 0 | 01-12-2008 12:59 PM |
| Clicking noise when spin cycle starts | Daniel Fox | Washer Repair | 0 | 11-04-2007 01:25 PM |
