after replacing water inlet valve (part # 9724754), the wash cycle begins but does not fill with enough water. Cycle continues (with inadequate water level) until 31 minutes remain in the cycle and control board flashes "CA". then after restarting the cycle the control board flashes "Cl" and concurrently beeps twice. everything stops at this point.
