Discuss
Maytag suds-saver problem
 in
Washer Repair
During the rinse cycle the rinse water pumps into the suds saver sink, causing it to overflow. This rinse water
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag suds-saver problem
  #1 (permalink)
Old 12-07-2009, 09:34 AM
Junior Member
Makky is on a distinguished road
Question Maytag suds-saver problem
Model Number: LAW9304AAE   Brand: Maytag   Age: 5 - 10 years
causing it to overflow. This rinse water should go directly down the drain.
Does this sound like a pump malfunction.
Thank you for any help
MAKKY
Related Models
Maytag LAW9304AAE WASHER-TOP LOADING
Maytag LAW9304AAL WASHER-TOP LOADING
Maytag LAW9304AAM WASHER-TOP LOADING
Maytag LAW9304ABE WASHER-TOP LOADING
Maytag LAW9400AAL WASHER-TOP LOADING
Maytag LAW9400AAW WASHER-TOP LOADING
Maytag LAW9400ABL WASHER-TOP LOADING
Maytag LAW9400ABW WASHER-TOP LOADING
Maytag LAW9406AAE WASHER-TOP LOADING
Maytag LAW9406ABE WASHER-TOP LOADING
Maytag LAW9700AAL WASHER-TOP LOADING
Maytag LAW9700AAW WASHER-TOP LOADING
Maytag LAW9700ABL WASHER-TOP LOADING
Maytag LAW9700ABW WASHER-TOP LOADING
Maytag LAW9704AAE WASHER-TOP LOADING
Maytag LAW9704AAL WASHER-TOP LOADING
Maytag LAW9704AAM WASHER-TOP LOADING
Maytag LAW9704ABE WASHER-TOP LOADING
 LB1200ER Air Conditioner
Whirlpool LB3000XKW0
Whirlpool LB3000XLW0
Whirlpool LB5300XKW0
Whirlpool LB5300XLW0
Whirlpool LB5500XKW0
Whirlpool LB5500XLW0
Whirlpool LB5540XMN0
 LB8000ER Air Conditioner
 LB8000R Air Conditioner
 LBC22518ST Refrigerator
 LBC22518WW Refrigerator
 LBC22520ST Refrigerator
 LBC22520SW Refrigerator
 LBC22520TT Refrigerator
 LBN22515SB Refrigerator
 LBN22515ST Refrigerator
 LBN22515WW Refrigerator
Amana LBP26AA0Y RANGE- S/I STD GAS
Amana LBP26AA5Y RANGE- S/I STD GAS
Whirlpool LBR1121EW0
Whirlpool LBR1121EW1 AUTOMATIC WASHER
Admiral LBR1415AGS RANGE- F/S STD ELE
Admiral LBR1415AGW RANGE- F/S STD ELE
Whirlpool LBR2121DW0
Whirlpool LBR2132BW0
Whirlpool LBR2132BW1
Whirlpool LBR4121JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LBR4121JQ1 WASHER - DIRECT DRIVE
Whirlpool LBR4121JQ2 WASHER
Whirlpool LBR4132BW0 AUTOMATIC WASHER
Whirlpool LBR4132HQ0 AUTOMATIC WASHER
Whirlpool LBR4132HQ1 AUTOMATIC WASHER
Whirlpool LBR4132JQ0 COMPACT WASHER
Whirlpool LBR4132JQ1 WASHER
Whirlpool LBR4132JQ2 AUTOMATIC WASHER
Whirlpool LBR4132PQ0 AUTOMATIC WASHER
Whirlpool LBR4132PQ1 AUTOMATIC WASHER
Whirlpool LBR4132PQ2 AUTOMATIC WASHER
Whirlpool LBR4221EW0
Whirlpool LBR4221EW1 AUTOMATIC WASHER
Whirlpool LBR4232DW0
Whirlpool LBR5132JQ1 WASHER - DIRECT DRIVE
Whirlpool LBR5133AG0
Whirlpool LBR5133AG1
Whirlpool LBR5133AN0
Whirlpool LBR5133AN1
Whirlpool LBR5133AW0
Whirlpool LBR5133AW1
Whirlpool LBR5232EQ0
Whirlpool LBR5232EQ1
Whirlpool LBR5232EQ2 AUTOMATIC WASHER
Whirlpool LBR5232EZ0
Whirlpool LBR5232EZ1
Whirlpool LBR5232EZ2 AUTOMATIC WASHER
Whirlpool LBR5432JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LBR5432JQ1 WASHER
Whirlpool LBR5432JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LBR5432JT1 WASHER
Whirlpool LBR5432LQ0 WASHER - DIRECT DRIVE
Whirlpool LBR5432LQ1 AUTOMATIC WASHER
Whirlpool LBR5432PQ0 AUTOMATIC WASHER
Whirlpool LBR5432PQ1 AUTOMATIC WASHER
Whirlpool LBR5432PQ2 AUTOMATIC WASHER
Whirlpool LBR5432PT0 AUTOMATIC WASHER
Whirlpool LBR5432PT1 AUTOMATIC WASHER
Whirlpool LBR5432PT2 AUTOMATIC WASHER
Whirlpool LBR6133DQ0
Whirlpool LBR6133DZ0
Whirlpool LBR6233AG0
Whirlpool LBR6233AN0
Whirlpool LBR6233AW0
Whirlpool LBR6233AW1
Whirlpool LBR6233DQ0
Whirlpool LBT6133AG0
Whirlpool LBT6133AN0
Whirlpool LBT6133AW0
Whirlpool LBT6133AW1
Whirlpool LBT6233DQ0
Whirlpool LBV5133AG0
Whirlpool LBV5133AN0
Whirlpool LBV5133AW0
Amana LC-10.000 COMMERCIAL MICROWAVES
Amana LC-10VP.000 COMMERCIAL MICROWAVES
Amana LC-14.000 COMMERCIAL MICROWAVES
Amana LC-14.001 COMMERCIAL MICROWAVES
Amana LC-14VP.000 COMMERCIAL MICROWAVES
Amana LC10EVP.000 COMMERCIAL MICROWAVES
Frigidaire LC120DH5 Frg(v2) / Laundry Center
Frigidaire LC120DL5 Frg(v3) / Laundry Center
Frigidaire LC120DW5 Frg(v1) / Laundry Center
Frigidaire LC120FH1 Frg(v3) / Laundry Center
Frigidaire LC120FL0 Frg(v2) / Laundry Center
Frigidaire LC120FL1 Frg(v2) / Laundry Center
Frigidaire LC120FW0 Frg(v1) / Laundry Center
Frigidaire LC120FW1 Frg(v1) / Laundry Center
Frigidaire LC120JL5 Frg(v1) / Laundry Center
Frigidaire LC120JW5 Frg(v2) / Laundry Center
Amana LC14EVP.000 COMMERCIAL MICROWAVES
Frigidaire LC248DH5 Frg(v2) / Laundry Center
Frigidaire LC248DL5 Frg(v3) / Laundry Center
Frigidaire LC248DW5 Frg(v1) / Laundry Center
  #2 (permalink)
Old 12-08-2009, 03:45 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Your suds saver assembly is an option that is found on very few machines. I have only worked on one, and with a similar problem as yours the problem was in the electrical system of the suds saver assembly.
I would take a look at the diversion valves/solenoids on the system and see if that is your problem.
__________________
  #3 (permalink)
Old 12-09-2009, 11:52 AM
Junior Member
Default
Thank you sidfink43.
That sounds like a good idea. I will check into that if I can find a manual. For may years I purchased Sears Kenmore washers. Those gave me so much trouble I got familiar with every possible part, including the electrical
timers. I have had this Maytag for about ten years and it has been trouble free, so I guess I will educate myself on this unit.
Makky
  #4 (permalink)
Old 12-09-2009, 02:40 PM
Senior Expert
APP Volunteer
Default
Good, you may to go in blind since I have not seen any tech notes or manual on this part of the machine.
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
soap suds are left in the bottom of the dishwasher faiths1 Dishwasher Repair 1 11-08-2009 04:25 AM
M-T WASHER STOPS DURING END OF SPIN CYCLE AND FLASHES SUdS...... FDAR Washer Repair 3 11-01-2009 09:27 PM
Suds Return on Maytag Washer bananaann Washer Repair 6 09-16-2009 11:07 AM
Dishwasher Leaking Suds tamimd Dishwasher Repair 1 01-06-2009 08:27 AM
hotpoint counter saver lpurring Heating, Ventilation, and Air Conditioning (HVAC) 0 01-01-2009 05:40 PM
