Discuss
noise when trying to spin in spin cycle
 in
Washer Repair
Dear RH Split the power cord outside the washer cabinet, and used amp clamp on the black wire. with the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » noise when trying to spin in spin cycle
  #11 (permalink)
Old 12-15-2009, 07:06 PM
Junior Member
ny17 is on a distinguished road
Default
Dear RH
Split the power cord outside the washer cabinet, and used amp clamp on the black wire. with the washer set to super plus for a full tank of water, the amp probe measured at most 8.6 and at least 8.0 amps during the spin cycle. it never reached 10 amps and never fell lower than 8.0. OK, or what do you think? thank you for your most valuable help by the way.
  #12 (permalink)
Old 12-16-2009, 01:18 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
That is a safe current level for the motor and I assume now you have no more noise.
In my "stickey" I explain that the tranny nylon gear can be damaged by a high impact load like a load of sneakers with insufficient water. Maybe that is the reason your tranny failed.
__________________
  #13 (permalink)
Old 12-16-2009, 04:27 AM
Junior Member
Default
RH,
Your the man, Thank you
  #14 (permalink)
Old 12-16-2009, 06:07 AM
Senior Expert
APP Volunteer
Default
Thank you, and I assume the washer is spinning up to full speed.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
spin cycle makes grinding noise, no spin jgungho Washer Repair 1 12-24-2009 09:28 AM
bearing noise during spin cycle donk95023 Washer Repair 1 11-18-2009 07:13 AM
Clunking noise when spin cycle is through chiefski Washer Repair 1 10-10-2009 02:53 AM
spin cycle noise tolfox Washer Repair 3 02-11-2009 01:37 AM
Noise during spin Cycle TTfool78 Washer Repair 6 01-31-2008 09:36 PM
