Register | FAQ's | New Posts | Today's Posts | Extras |
» Kenmore Whasher fills up w/ water then stops |
![]() Model Number: 110.24422300 Brand: Kenmore Age: 1 - 5 years
![]() I've got a Kenmore washer (top loader) Model #:110.24422300. I start a load and it fills up with water as it normally does, and then it just stops. No noises, no smells. I've turned the knob to several other cycles to see if it would start back on but nothing happens. From what I've read in other threads, it looks like it could be the lid switch?!? Is this the only thing I should check/replace before I start dismantling? Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Top loading washer fills with water then stops | acdiii | Washer Repair | 1 | 01-02-2010 09:09 AM |
my washer stops after the water fills | sandraquin | Washer Repair | 1 | 12-23-2009 06:40 PM |
Washer fills with water then stops | mindylea | Washer Repair | 1 | 04-01-2009 07:15 PM |
washer stops after water fills suspect timer | alpierro | Washer Repair | 13 | 06-22-2008 01:18 PM |
water fills and stops intermittently | worldtravelert | Washer Repair | 0 | 12-08-2007 09:50 AM |
