| » washer doesn't spin fast enough |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: 11016101690 Brand: Sears Age: More than 10 years
Waher will do everything but spin fast enogh to ring out the clothes. The clothes are dripping wet. what should I check first?
A cause of the problem could be:
1. Overloaded washer. 2. Clogged drain or kinked drain hose. 3. A foreign object stuck between the inner and the outer tubs. 4. A bad drive block. 5. A bad clutch. The first thing I would do is make a smaller load and see how it will work. Check the drain hose behind the washer. Remove the cabinet and check the drain hoses, the pump and look through the outer tub for a stuck clothes. Check the drive block. Post your findings. Gene.
__________________
Professional appliance repair services in Orange County, California. |
| Display Modes | |
| spins fast sounds like an airplane noise | starla87 | Washer Repair | 1 | 02-25-2008 01:47 PM |
| washer won't spin in final spin cycle | amie48 | Washer Repair | 0 | 01-12-2008 12:59 PM |
| Frig. needs hepl fast | Kelli_Shffr | Refrigerator & Freezer Repair | 1 | 11-27-2007 04:47 PM |
| inner wash basket thumping on fast spin | sandlmax | Washer Repair | 2 | 08-14-2007 05:28 AM |
| Kenmore Won't spin fast enough | imswear | Washer Repair | 0 | 07-30-2007 11:13 AM |
