Discuss
Washer will not stop filling and tub leaks
 in
Washer Repair
The washer will not stop filling up. I noticed on this blog that this may be a problem with the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer will not stop filling and tub leaks
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-12-2008, 12:41 PM
t7433 t7433 is offline
Junior Member
t7433 is on a distinguished road
Default Washer will not stop filling and tub leaks
Model Number: ALW880AQC   Brand: Amana   Age: 1 - 5 years
The washer will not stop filling up. I noticed on this blog that this may be a problem with the pressure hose switch that may of come off. Mine after filling up and turning timer to get it to stop filling up and spin out I noticed a steady stream of water leaking from the left front of the bottom outer tub. Could that be caused by the pressure hose switch?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-13-2008, 11:16 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Remove the bottom panel and check the pressure bulb and the pressure hose (#13 & #15 on the outer tub break down diagram).
Post your findings.
Here are the break down diagrams for the Amana washer Model ALW880QAC
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer leaks when filling and draining jds.girl_2006 Washer Repair 1 02-11-2008 04:25 PM
Washer leaks when filling and draing jds.girl_2006 Washer Repair 1 02-11-2008 04:24 PM
washer won't stop filling!!!! dalejrmaniac Washer Repair 13 12-26-2007 12:48 PM
washer won't stop filling mnestinger Washer Repair 1 11-14-2007 11:25 AM
Washer will not stop filling Mwaters583 Washer Repair 1 10-26-2007 09:59 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
