Discuss
Timer Control Knob Removal
 in
Washer Repair
I have just ordered a replacement timer control assembly from AppliancePartsPros.com Part Details - MAYTAG Timer/4 cycle, part number:
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Timer Control Knob Removal
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-12-2008, 10:03 AM
Abaco Abaco is offline
Junior Member
Abaco is on a distinguished road
Default Timer Control Knob Removal
Model Number: LWM833W   Brand: Amana   Age: More than 10 years
I have just ordered a replacement timer control assembly from AppliancePartsPros.com Part Details - MAYTAG Timer/4 cycle, part number: AP83145
How do I get the knob off of this part. When I turn it counter clockwise, either pushed in or pulled out it just spins.
Thank you for any help you can provide.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-13-2008, 07:25 PM
jgreen jgreen is offline
Junior Member
jgreen is on a distinguished road
Default
On mine you have to have knob pushed in , then turn counter clockwise to remove. Question for you, why did you have to replace timer?
I am having problems and I think it is the timer /swith control.
washer fills, then it should start to wash(agitate) but doesn't all the time. You can here the timer clicking but it won't wash. If I turn knob over to perm press wash it will wash a little then stop, if I turn knob a little it will start again to wash. Then it goes thru spin cycle it seems ok.
  #3 (permalink)
Old 03-14-2008, 09:39 AM
Junior Member
Default
Hi jgreen,
Thank you for your info. I was able to get the knob to finally screw off after alot of trying. Knowing that it did screw off allowed me to be persistant enough to remove it.
The timer was working correctly as far as the wash cycles go, but the knob no longer worked when you wanted to turn the timer from one type of cycle to another. To do this you had to press hard on the larger plastic ring under the knob to get it to turn. I think that the ratchet latch inside of the timer finally wore out. My guess is that it is plastic and was probably designed to fail later in its life. Therefore I am replaceing a mostly working part because they used a cheap little plastic part in side the timer.
Again, Thanks for your response.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How do I remove large timer knob w/o breaking it? beaumart@plateautel.net Washer Repair 2 07-03-2008 03:44 PM
Unable to remove GE timer knob andyhutch Washer Repair 1 03-02-2008 04:44 AM
bosch program knob removal boffin Washer Repair 0 12-01-2007 07:24 AM
control knob broke off jugular5 Refrigerator & Freezer Repair 0 08-14-2007 12:04 PM
Timer wires what color wire to which knob? helpless0077 Dryer Repair 1 08-10-2007 08:18 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
