Discuss
roper washer not spinning on spin cycle
 in
Washer Repair
not spinning out on spin cycle. i have crossed lid switch with wire and it was barely spinning. water is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » roper washer not spinning on spin cycle
  #1 (permalink)
Old 12-03-2009, 05:42 PM
Junior Member
walkm0217 is on a distinguished road
Default roper washer not spinning on spin cycle
Model Number: ras7133rq4   Brand: Roper   Age: 1 - 5 years
not spinning out on spin cycle. i have crossed lid switch with wire and it was barely spinning. water is pumping out. i also changed the motor/gearbox coupling.thanks mark.
Related Models
Roper RAS7133RQ4 AUTOMATIC WASHER
Roper RAS7233JQ0 WASHER
Roper RAS7233KQ0 WASHER
Roper RAS8244KQ0 WASHER
Roper RAS8244KQ1 AUTOMATIC WASHER
Roper RAS8244KQ2 AUTOMATIC WASHER
Roper RAS8244LQ0 AUTOMATIC WASHER
Roper RAS8244LQ1 AUTOMATIC WASHER
Roper RAS8245EN0 DIRECT DRIVE WASHER
Roper RAS8245EN1 DIRECT-DRIVE WASHER
Roper RAS8245EQ0 DIRECT DRIVE WASHER
Roper RAS8245EQ1 DIRECT-DRIVE WASHER
Roper RAS8245EW0 DIRECT DRIVE WASHER
Roper RAS8245EW1 DIRECT-DRIVE WASHER
Roper RAS8333PQ0 AUTOMATIC WASHER
Roper RAS8333PQ1 AUTOMATIC WASHER
Roper RAS8333RQ0 AUTOMATIC WASHER
Roper RAS8333RQ1 AUTOMATIC WASHER
Roper RAS8333RQ3 AUTOMATIC WASHER
Roper RAS8333RQ4 AUTOMATIC WASHER
Roper RAS8445JQ0 WASHER
Roper RAS8445KQ0 WASHER
Maytag RAX1000AXW MISC / ACCESSORY
Maytag RAX1000CXB MISC / ACCESSORY
Maytag RAX2000AXW MISC / ACCESSORY
Maytag RAX2000CXB MISC / ACCESSORY
Maytag RAX3000DXX MISC / ACCESSORY
Maytag RAX33 MISC / ACCESSORY
Maytag RAX3300CXX MISC / ACCESSORY
Maytag RAX34 MISC / ACCESSORY
Maytag RAX36 MISC / ACCESSORY
Maytag RAX3600CXX MISC / ACCESSORY
Roper RAX4232JQ0 WASHER
Roper RAX4232KQ0 WASHER
Roper RAX4232KQ1 AUTOMATIC WASHER
Roper RAX4232PQ0 AUTOMATIC WASHER
Roper RAX4232PQ1 AUTOMATIC WASHER
Roper RAX4232RQ0 AUTOMATIC WASHER
Roper RAX4232RQ1 AUTOMATIC WASHER
Roper RAX4232RQ3 AUTOMATIC WASHER
Roper RAX4232RQ4 AUTOMATIC WASHER
Roper RAX4233PQ0 AUTOMATIC WASHER
Maytag RAX5000AXB MISC / ACCESSORY
Maytag RAX5000CXB MISC / ACCESSORY
Maytag RAX5100AXB MISC / ACCESSORY
Whirlpool RAX5133AG0
Whirlpool RAX5133AL0
Roper RAX5133AL1 AUTOMATIC WASHER
Roper RAX5133AW0 Washers*
Maytag RAX5200AXB MISC / ACCESSORY
Maytag RAX5200CXB MISC / ACCESSORY
Maytag RAX5300AXB MISC / ACCESSORY
Maytag RAX5400AXB MISC / ACCESSORY
Maytag RAX5500AXB MISC / ACCESSORY
Maytag RAX5500CXB MISC / ACCESSORY
Maytag RAX5600AXB MISC / ACCESSORY
Maytag RAX5700AXB MISC / ACCESSORY
Maytag RAX5700CXB MISC / ACCESSORY
Whirlpool RAX6144EN0
Whirlpool RAX6144EN1
Whirlpool RAX6144EQ0
Whirlpool RAX6144EQ1
Whirlpool RAX6144EW0
Whirlpool RAX6144EW1
Roper RAX7244EN0 WASHER
Roper RAX7244EN1 WASHER
Roper RAX7244EQ0 WASHER
Roper RAX7244EQ1 WASHER
Roper RAX7244EW0 WASHER
Roper RAX7244EW1 WASHER
Roper RAX7244JQ0 WASHER
Roper RAX7244KQ0 WASHER
Roper RAX7244KQ1 AUTOMATIC WASHER
Roper RAX7244KQ2 AUTOMATIC WASHER
Roper RAX7244PQ0 AUTOMATIC WASHER
Roper RAX7244PQ1 AUTOMATIC WASHER
Whirlpool RAX7245AG0
Whirlpool RAX7245AL0
Roper RAX7245AW0 Washers*
Roper RAX7245BL1 AUTOMATIC WASHER
Roper RAX7245BQ1 AUTOMATIC WASHER
Roper RAX7245BW0 DIRECT-DRIVE AUTOMATIC WASHER
Roper RAX7245BW1 AUTOMATIC WASHER
Roper RAX7245JQ0 WASHER
Roper RAX7245KQ0 WASHER
Roper RAX7245KQ1 AUTOMATIC WASHER
Whirlpool RB1000XKW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XKW1 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XKW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XVW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XVW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB1000XVW3 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYN2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB1005XYN3 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYN5 24" ELECTRIC OVEN
Whirlpool RB1005XYW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYW2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB1005XYW3 ELECTRIC BUILT-IN OVEN
Whirlpool RB1005XYW5 24" ELECTRIC OVEN
Whirlpool RB100PXK-0 24" ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXK0
Whirlpool RB100PXK1 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXK2 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXV0 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXV2 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXV3 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXYB0 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXYB2 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB100PXYB3 ELECTRIC BUILT-IN OVEN
Whirlpool RB100PXYB5 24" ELECTRIC BUILT-IN STANDARD CLEAN OVEN
Whirlpool RB1200XKW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1200XKW1 ELECTRIC BUILT-IN OVEN
Whirlpool RB1200XKW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB1200XVW0 ELECTRIC BUILT-IN OVEN
Whirlpool RB1200XVW2 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXK1 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXK2 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXV0 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXV1 ELECTRIC BUILT-IN OVEN
Whirlpool RB120PXV2 ELECTRIC BUILT-IN OVEN
  #2 (permalink)
Old 12-05-2009, 03:50 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
A bad clutch is typically the source of this problem. Take off the agitator then take off the motor as you did to replace the coupling. The transmission will now come out by removing three bolts, and you can replace the clutch.
Part Details - WHIRLPOOL Clutch assembly, part number: AP3094537
__________________
  #3 (permalink)
Old 12-07-2009, 08:41 AM
Junior Member
Default
Quote:
update!! thanks sidfink for your help the clutch fixed it.
  #4 (permalink)
Old 12-07-2009, 10:16 AM
Senior Expert
APP Volunteer
Default
Fantastic, glad that worked, and thanks for the update
__________________
  #5 (permalink)
Old 12-07-2009, 01:30 PM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
You might want to put an amprobe on the power wire to the washer to make sure the motor is not drawing above 10 amps in spin. If it is, your motor might fail or just burn up.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tub Not Spinning on Spin Cycle RHH Washer Repair 0 01-21-2010 09:14 PM
Washer drum not spinning on spin cycle Duane Francis Washer Repair 0 10-22-2009 02:48 PM
doesn't always spin cycle Roper Washer kalahiki Washer Repair 8 07-12-2009 03:41 PM
roper washer wont work on spin cycle bugdude007 Washer Repair 1 05-31-2009 10:10 AM
Washer not spinning through spin cycle gdonwallace Dishwasher Repair 1 01-27-2009 01:23 PM
