Discuss
washer cycle won't advance
 in
Washer Repair
I recently replaced the timer because I assumed that if the knob wouldn't advance on its own that the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer cycle won't advance
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-10-2008, 11:59 PM
tlaw63 tlaw63 is offline
Junior Member
tlaw63 is on a distinguished road
Default washer cycle won't advance
Model Number: 110-72982600   Brand: Kenmore   Age: More than 10 years
I recently replaced the timer because I assumed that if the knob wouldn't advance on its own that the timer was bad. I can manually advance the cycles and they work fine. The knob just won't turn on its own. The new timer made no difference! I know this is an older model and I can find very little info on it I don't want to sink much more money into it but since I already spent the $90 for the timer thought I would post for help? ( Kenmore 110*72982600 washer)
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-11-2008, 03:11 PM
Matt S Matt S is offline
Senior Expert
APP Volunteer
Matt S is on a distinguished road
Default
Is it filling with cold water? If the machine does not fill with cold water the timer will stall in the rince cycle.
Also, if the drain hose is stuffed far down the stand pipe, the timer will get stuck in the perma-press cycle.
Matt
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Washing Machine cycle doesn't advance Bruce Kile Washer Repair 4 06-23-2008 06:32 PM
dryer blows cold air won't advance through cycle sandra626 Dryer Repair 4 02-05-2008 10:49 AM
GE WASHER will not advance gewasher123 Washer Repair 1 01-07-2008 11:42 AM
Maytag Atlantis won't go automatically advance to rinse cycle rmjz12 Washer Repair 1 11-15-2007 08:56 AM
Cycle won't advance dbarnard Washer Repair 0 09-24-2007 09:37 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
