Discuss
Calypso Washer Washer Won't Drain
 in
Washer Repair
Does anyone know how to change the drain pump on a Calypso washing machine? Somewhere along the line the darn
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Calypso Washer Washer Won't Drain
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-18-2007, 09:48 AM
SamB SamB is offline
Junior Member
SamB is on a distinguished road
Default Calypso Washer Washer Won't Drain
Model Number: GVW9959KQ   Brand: Whirlpool   Age: 1 - 5 years
Somewhere along the line the darn serial number tag came off the unit and now even though I have a warranty, nobody will work on the thing. So I guess I will have to fix it myself.
Has anyone in the forum ever done this themselves?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-27-2007, 01:14 PM
pinksunrise pinksunrise is offline
Junior Member
pinksunrise is on a distinguished road
Unhappy
I have the same washer/dryer and I have a similiar problem. Let me know if you come up with any answers. I talked to someone at Lowe's who said to turn it on it's side, and pull out anything that might be clogging the drain. I know that is not too much, if any help.
  #3 (permalink)
Old 11-27-2007, 01:40 PM
Junior Member
Default Fixed the drain problem
Thanks for the information on the fix for the drain problem. If you are having the same problem the guys at Lowes are correct. Tilt the unit back so you can safely work under it. Find the drain line leading from the drain pump to the back of the poly tub. At the bottom where the drain line connects is a sump with a "ball check valve" built into it. Remove the drain lines, have a bucket or pan handy, and pull out any gunk that might be keeping the "ball check" from seating properly. I found 4 of the underwires from by wifes bras stuck in there.
Also, depending on the age of your unit it sounds like some of the early models had drain pumps that were not very well made. If you need a new drain pump it looks like they would be easy to replace from what I could tell when I had mine apart.
Sam
  #4 (permalink)
Old 11-27-2007, 01:41 PM
Junior Member
Default
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer won't drain jmsnewton Washer Repair 5 09-04-2007 10:45 PM
Washer won't drain or spin carrol Washer Repair 2 08-20-2007 06:37 AM
Washer won't drain during spin cycle. Water Pump Belt discovered on floor sandydjdm Washer Repair 1 08-14-2007 07:41 PM
Washer will spin slowly but not drain Mikie Martin Washer Repair 0 07-31-2007 07:36 AM
Whirlpool Calypso error shola Washer Repair 0 07-30-2007 10:43 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
