AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Maytag Top load not working, making clicking noise
Our Maytag LAT9600AAL Top load washer has stopped working after filling with water. Currently all the washer does is make a ticking and buzzing/grinding noise from the timer area. I checked the fuse and it's fine. No matter what setting I select it just keeps making the ticking and buzzing/grinding noise. When I open the lid it stops but continues once I close the lid, I'm assuming the lid switch is working.
Would this most likely be the timer switch?
Clarusmoof
Washer Repair
