Discuss
washer spins slow or doesn't spin
 in
Washer Repair
I have an admiral giant capacity plus heavy duty 20 lb top load washer. during washing cycles it will slow
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer spins slow or doesn't spin
  #1 (permalink)
Old 11-30-2009, 11:24 AM
Junior Member
lordpuckx is on a distinguished road
Default washer spins slow or doesn't spin
Model Number: LNC6742A80   Brand: Admiral   Age: More than 10 years
I have an admiral giant capacity plus heavy duty 20 lb top load washer. during washing cycles it will slow down and or stop and will not spin at the correct speed. what parts do i need to get for this? do i need to replace a belt or is it a bearing thing? please advice, thank you.
Ads By Google
Related Models
International LNC6760A71 Washer - Top Loading
Admiral LNC6760B71 Washer - Top Loading
International LNC6762A01 Washer - Top Loading
Admiral LNC6762A01 Washer - Top Loading
International LNC6762A71 Washer - Top Loading
Admiral LNC6762A71 Washer - Top Loading
International LNC6762A77 Washer - Top Loading
Admiral LNC6762A77 Washer - Top Loading
Admiral LNC6762B01 Washer - Top Loading
Admiral LNC6762B71 Washer - Top Loading
Admiral LNC6764A00 Washer - Top Loading
Admiral LNC6764A71 Washer - Top Loading
Admiral LNC6766A00 Washer - Top Loading
Admiral LNC6766A01 Washer - Top Loading
Admiral LNC6766A71 Washer - Top Loading
Admiral LNC6766A77 Washer - Top Loading
Admiral LNC6766B71 Washer - Top Loading
Admiral LNC7760A00 Dryer - Ele
Admiral LNC7760A71 Dryer - Ele
Admiral LNC7764A00 Dryer - Ele
Admiral LNC7764A71 Dryer - Ele
Admiral LNC7764A77 Dryer - Ele
Admiral LNC7766A00 Dryer - Ele
International LNC7766A00 Dryer - Ele
Admiral LNC7766A71 Dryer - Ele
International LNC7766A71 Dryer - Ele
Admiral LNC7766B71 Dryer - Ele
International LNC8760A00 Dryer - Gas
International LNC8760A01 Dryer - Gas
International LNC8760A71 Dryer - Gas
International LNC8760A77 Dryer - Gas
Admiral LNC8764A00 Dryer - Gas
Admiral LNC8764A71 Dryer - Gas
Admiral LNC8766A00 Dryer - Gas
International LNC8766A00 Dryer - Gas
Admiral LNC8766A71 Dryer - Gas
International LNC8766A71 Dryer - Gas
Admiral LNC8766B71 Dryer - Gas
Amana LP13300.A Mwave - Family Size (60 Hz)
Amana LP13300.B Mwave - Family Size (60 Hz)
Amana LP13600.A Mwave - Family Size (60 Hz)
Amana LP13600.B Mwave - Family Size (60 Hz)
Amana LP13610.A Mwave - Family Size (60 Hz)
Amana LP13610.B Mwave - Family Size (60 Hz)
Amana LP16400.A Mwave - Family Size (60 Hz)
Amana LP16400.B Mwave - Family Size (60 Hz)
Amana LP16600.A Mwave - Family Size (60 Hz)
Amana LP16600.B Mwave - Family Size (60 Hz)
Amana LP16610.A Mwave - Family Size (60 Hz)
Amana LP16610.B Mwave - Family Size (60 Hz)
Amana LP24400.A Mwave - Family Size (60 Hz)
Amana LP24400.B Mwave - Family Size (60 Hz)
Amana LP24600.A Mwave - Family Size (60 Hz)
Amana LP24600.B Mwave - Family Size (60 Hz)
Amana LP83400.A Mwave - Family Size (60 Hz)
Amana LP83400.B Mwave - Family Size (60 Hz)
Amana LP83430.A Mwave - Family Size (60 Hz)
Amana LP83430.B Mwave - Family Size (60 Hz)
Amana LP83600.A Mwave - Family Size (60 Hz)
Amana LP83600.B Mwave - Family Size (60 Hz)
Amana LP83620.A Mwave - Family Size (60 Hz)
Amana LP83630.A Mwave - Family Size (60 Hz)
Amana LP83630.B Mwave - Family Size (60 Hz)
Admiral LPK5404ARW Kitchen Compact
Admiral LPK5404ARZ Kitchen Compact
Admiral LPR1115ADW Range - F/s Std Gas
Whirlpool LPR4231AG0
Whirlpool LPR4231AN0
Whirlpool LPR4231AW0
Whirlpool LPR6244AN0
Whirlpool LPR6244AW0
Maytag LRSC20A Ref - Sxs
Maytag LRSD20A Ref - Sxs
Maytag LRSD22A Ref - Sxs
Maytag LRSD24A Ref - Sxs
Maytag LRSW22A Ref - SXS/I&W
Maytag LRSW24A Ref - SXS/I&W
  #2 (permalink)
Old 11-30-2009, 03:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Tilt the washer back and remove the belt. Inspect the belt for any damages. Check how freely the pump pulley is moving in both directions. Post the results.
The model number you posted oes not come up. Verify and repost it. How old is the washer?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 11-30-2009, 04:01 PM
Junior Member
Default admiral washer
the model number is # LNC6742A80
SERIAL# 49F378833
We bought it from montgomery wards in 1991. old model.
it is an admiral giant capacity plus heavy duty 20lb washer. top load. it doesn't say the rev for it. hope this info helps. i'm pretty sure it has similar parts as other models of the same year. please let me know if you find anything. thanks
  #4 (permalink)
Old 11-30-2009, 04:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Unfortunately there is no online information available for such old models. You probably have to remove the front panel and check the belt first.
I believe the APP team can help you better over the phone (877-477-7278) with the correct part numbers because they have more access to old models information.
__________________
  #5 (permalink)
Old 11-30-2009, 04:26 PM
Junior Member
cool thanks. i'll check for the belt and i'll call them on it. maybe i can get a part number from the belt and or other parts on the machine. i'll let you know what happens.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer spins slow or needs help to spin BHileman Washer Repair 1 02-24-2010 07:04 PM
washer spins to slow captainda Washer Repair 1 12-06-2009 07:22 AM
hirlpool washer wont spin correctly(spins very slow) jre72 Washer Repair 1 08-21-2009 06:08 AM
washer spins slow kenfink Washer Repair 1 04-29-2009 05:43 PM
washer spins too slow soggyclothes Washer Repair 1 02-10-2009 01:17 PM
