Discuss
sock stuck in water pump... do i need a new pump?
 in
Washer Repair
so ive learned my lesson not to have baby socks in a washer unless its in a special bag. Anyways
Appliance Repair Forum > Appliance Repair Help > Washer Repair » sock stuck in water pump... do i need a new pump?
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-08-2008, 07:20 PM
volcompunker82 volcompunker82 is offline
Junior Member
volcompunker82 is on a distinguished road
Default sock stuck in water pump... do i need a new pump?
Model Number: dlw330raw   Brand: Amana   Age: 5 - 10 years
so ive learned my lesson not to have baby socks in a washer unless its in a special bag. Anyways my problem is this. a suck got jammed in the water pump. i pulled it out. the pump still dont pump but yet i spun the blade inside and it spun freely.. i have a direct drive which the motor goes into the pump. my question now is do i need a new pump? there is no other blockage water comes out freely on a gravity feed. i have it temporarily hook up where it drains outside because it wont pump in the correct drain. also now it gets stuck on the rinse cycle and the water keeps draining? does this have to do with anything or is this a totally different problem? and if so i do i go about repairing this.
thank you for your time for reading and replying
Joe
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water Won't Pump Out/burning Smell Gena Washer Repair 3 01-03-2008 10:32 PM
Washer won't spin or pump water out nikki afinowicz Washer Repair 0 12-09-2007 07:41 AM
water pump ? CAT88 Washer Repair 0 10-27-2007 11:24 AM
LG pump may be bad or have something stuck Jamiepe Washer Repair 2 10-24-2007 10:16 AM
water pump going bad CAT88 Washer Repair 1 10-23-2007 04:42 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
