Discuss
Washer won't drain or spin
 in
Washer Repair
Just recently my washer decided that two spins a cycle was too much. It will fill,wash and drain on
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't drain or spin
  #1 (permalink)
Old 08-18-2007, 07:34 AM
carrol carrol is offline
Junior Member
carrol is on a distinguished road
Angry Washer won't drain or spin
Brand: Hotpoint   Age: 1 - 5 years
Just recently my washer decided that two spins a cycle was too much. It will fill,wash and drain on first cycle, then fill and die on the rinse cycle. If I jank the machine back and forth, sometimes it will catch and begin draining and spinning--and sometimes it won't. Sometimes if I bail out most of the water it will catch and spin. Moving the knob around to different cycles has no effect--trying to turn the agitator by hand doesn't work. I am becoming very sore and brusied trying to wash laundry--any ideas that might help would be greatly appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-18-2007, 03:23 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Carrol,
Sounds like the problem with your washer is a bad lid switch, but in order to help you better I need the complete model number of your washer. You can find it on top of the control panel.
  #3 (permalink)
Old 08-20-2007, 07:37 AM
Junior Member
Default
Gene,
The model number is VBXR1090D5CC. I purchased it inFeb.'05 and thought it would outlive me. Guess I must be dead--because it has died. We have foster children in our home and I NEED MY MACHINE. I know that on the top of the machine there is a magnetic white strip-and when I open or close the lid, I hear it click. How do I get the strip off?
Thanks for your input.
Carrol
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Will not drain or spin. PJ3 Washer Repair 1 11-15-2007 06:14 PM
washer won't drain jmsnewton Washer Repair 5 09-04-2007 11:45 PM
Washer won't drain during spin cycle. Water Pump Belt discovered on floor sandydjdm Washer Repair 1 08-14-2007 08:41 PM
After wash cycle will not drain and spin out IndianaPanda Washer Repair 0 08-08-2007 01:15 PM
Washer will spin slowly but not drain Mikie Martin Washer Repair 0 07-31-2007 08:36 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
