I just purchased a new Control ASM for my GE Washing Machine. The old ASM went bad. I installed the new ASM and all the lights on the ASM are blinking and the machine will not start. Is this a bad board? Or is there a reset switch that I need to hit.
Thanks John Moore
I hope that you still have your old Control ASM as there should be another connector on it that needs to be transfered to the new Control ASM. It should look like a loop back connector with some wires in the plug. You need to transfer this plug from the old Control ASM to the new Control ASM in order for the Control ASM to work correctly. If not all the lights will blink showing an open circuit on the new Control ASM and washer will not work. Hope this helps.
Thanks for the help, that worked for me
