Discuss
Intermittent problem with the dry cycle
 in
Washer Repair
Got this top loading washer and today I replaced the pump due to leaks but I also thought that would
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Intermittent problem with the dry cycle
  #1 (permalink)
Old 11-27-2009, 04:44 PM
Junior Member
bigotes is on a distinguished road
Default Intermittent problem with the dry cycle
Model Number: Roper RAL5144bq   Brand: Roper   Age: 5 - 10 years
Got this top loading washer and today I replaced the pump due to leaks but I also thought that would also take care of an intermittent problem where the washer will finish but leave clothes wet (it does spin, though). I jsut found out that the pump does not seem to be the source of that intermittent problem! Any suggestions?
When doing several loads in a row; most will be properly completed, but at least one will finish leaving clothes quite wet.
Ads By Google
Related Models
Frigidaire RP13M2WS2B Gib(v4) / Top Mount Refrigerator
Frigidaire RP13M2WS2C Gib(v5) / Top Mount Refrigerator
Frigidaire RP13M2WS2D Gib(v6) / Top Mount Refrigerator
Amana RR Mwave - Family Size (60 Hz)
Amana RR-1 Range - S/c S/i Ddraft Gas
Amana RR-10 Mwave - Family Size (60 Hz)
Amana RR-1000 Mwave - Cntrtp / Stand Alone
Amana RR-1010 Mwave - Cntrtp / Stand Alone
Amana RR-10A Mwave - Cntrtp / Stand Alone
Amana RR-1110 Mwave - Family Size (60 Hz)
Amana RR-1225 Mwave - Cntrtp / Stand Alone
Amana RR-3H Range - S/c S/i Ddraft Gas
Amana RR-4 Range - S/c S/i Ddraft Gas
Amana RR-4D Range - S/c S/i Ddraft Gas
Amana RR-4DW Range - S/c S/i Ddraft Gas
Amana RR-5B Mwave - Cntrtp / Stand Alone
Amana RR-6 Mwave - Family Size (60 Hz)
Amana RR-7 Range - S/c S/i Ddraft Gas
Amana RR-700 Range - S/c S/i Ddraft Gas
Amana RR-7A Mwave - Family Size (60 Hz)
Amana RR-7B Mwave - Cntrtp / Stand Alone
Amana RR-7D Mwave - Family Size (60 Hz)
Amana RR-7DA Mwave - Family Size (60 Hz)
Amana RR-8 Mwave - Family Size (60 Hz)
Amana RR-800 Mwave - Cntrtp / Stand Alone
Amana RR-810 Mwave - Cntrtp / Stand Alone
Amana RR-820 Mwave - Cntrtp / Stand Alone
Amana RR-8A Mwave - Family Size (60 Hz)
Amana RR-8B Mwave - Family Size (60 Hz)
Amana RR-8T Mwave - Cntrtp / Stand Alone
Amana RR-8TC Mwave - Cntrtp / Stand Alone
Amana RR-9 Range - S/c S/i Ddraft Gas
Amana RR-900 Mwave - Cntrtp / Stand Alone
Amana RR-910 Range - S/c S/i Ddraft Gas
Amana RR-9T Mwave - Family Size (60 Hz)
Amana RR-9TA Mwave - Family Size (60 Hz)
Amana RR-9TB Mwave - Cntrtp / Stand Alone
Amana RR-II Range - S/c S/i Ddraft Gas
Amana RR1020 Mwave - Cntrtp / Stand Alone
Amana RR1220 Mwave - Cntrtp / Stand Alone
Amana RR2 Mwave - Cntrtp / Stand Alone
Amana RR510 Mwave - Cntrtp / Stand Alone
Amana RR510A Mwave - Cntrtp / Stand Alone
Amana RR52 Mwave - Family Size (60 Hz)
Amana RR54 Mwave - Family Size (60 Hz)
Amana RR54D Mwave - Cntrtp / Stand Alone
Amana RR56 Mwave - Cntrtp / Stand Alone
Amana RR57D Mwave - Cntrtp / Stand Alone
Amana RR59T Mwave - Cntrtp / Stand Alone
Amana RR6W Mwave - Cntrtp / Stand Alone
Amana RR7 Mwave - Cntrtp / Stand Alone
Amana RR720 Mwave - Cntrtp / Stand Alone
Amana RR9 Mwave - Cntrtp / Stand Alone
Amana RR920 Mwave - Cntrtp / Stand Alone
Amana RRC57D Mwave - Cntrtp / Stand Alone
Amana RRH-10 Mwave - Family Size (60 Hz)
Whirlpool RRH260
Whirlpool RRH261
Whirlpool RRH262
Whirlpool RRH266
Amana RRL-10A Mwave - Family Size (60 Hz)
Amana RRL-10C Mwave - Cntrtp / Stand Alone
Amana RRL-10TD Mwave - Family Size (60 Hz)
Amana RRL-10XA Mwave - Family Size (60 Hz)
Amana RRL-5C Mwave - Family Size (60 Hz)
Amana RRL-5D Mwave - Cntrtp / Stand Alone
  #2 (permalink)
Old 11-28-2009, 08:53 PM
Senior Member
Qtip is on a distinguished road
Default
the two suspects that come to mind for me are the transmission or a center seal (more likely of my two suspects) thats gone bad but this specific problem i'm not very good with so i would see if others have suggestions. when you replaced the pump did you notice any obvious brown transmission fluid on the floor or on the walls of the washer casing?
  #3 (permalink)
Old 12-07-2009, 05:47 PM
Junior Member
Default
Actually I did notice some brown liquid on the floor. Is this an indication of a faulty transmission or just the seal?
  #4 (permalink)
Old 12-07-2009, 07:08 PM
Senior Member
Default
Not positive which would be the cause but its definitely either the transmission itself (the only part in the machine that would hold brownish/blackish fluid) or that seal
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
intermittent furnace problem depa007 Heating, Ventilation, and Air Conditioning (HVAC) 0 12-10-2009 02:28 PM
Intermittent Problem w/ Heat rjl41 Dryer Repair 0 12-09-2009 04:48 PM
Intermittent burner problem bs81753 Oven Repair (including Ranges and Cooktops) 3 07-31-2009 03:44 PM
Intermittent Problem matned Microwave Repair 17 03-05-2009 09:51 PM
Intermittent Problem reed2112 Refrigerator & Freezer Repair 5 12-28-2008 03:15 AM
