vic21772
#1 Posted : Friday, November 27, 2009 9:35:59 AM(UTC)
vic21772
My washer stopped spinning, So of course I took it apart. I found that one side of the motor coupling was broken in half. I glued it back together and let it set over night unfortunetly it didn't hold. My question I guess is, is there that much torque there or did I not put it back together right, I ordered a new one just a few minutes ago and I want to make sure I am not doing some thing wrong. I am a little confussed wether or not I need to line up the Basket drive and brake assembly and Clutch assembly a certian way or if I just slide everything back together and I'm good to go? I just don't want to brake the new motor coupling when I put everthing back together.
Qtip
#2 Posted : Friday, November 27, 2009 7:07:54 PM(UTC)
Qtip
The replacement motor coupling has a metal lining to prevent that part from breaking in the future. it is not possible to repair the coupling because there is way too much torque. There is no certain way to line it all back up just make sure the coupling slides in place and put the motor clips back on and all that good stuff and your good to go
motor coupling on top loader kenmore 500 (Washer Repair)
by gabslms 5/22/2021 5:04:32 PM(UTC)
Motor Coupling Parts Too Small? (Washer Repair)
by Pete Pliers 9/28/2015 12:15:19 PM(UTC)
Washer Motor Coupling Keeps Failing (Washer Repair)
by hunter02 2/8/2015 12:52:27 PM(UTC)
Whirlpool Direct Drive Washer Motor Coupling (Washer Repair)
by AwakenSatori 7/7/2013 3:44:40 PM(UTC)
Should Motor Coupling Turn Like This? (Washer Repair)
by winterland 3/14/2013 12:48:32 PM(UTC)
Whirlpool Washer won't spin/agitate. Replaced Direct Drive Motor Coupling. (Washer Repair)
by millmoss 9/10/2012 9:52:02 AM(UTC)
Is the motor coupling the problem in my washer? (Washer Repair)
by skydragon 7/29/2012 10:23:59 AM(UTC)
How to tell if motor coupling is defective (Washer Repair)
by River Rat 3/16/2012 6:23:08 PM(UTC)
replaced motor coupling now won't do anything (Washer Repair)
by mandilyn4 9/26/2011 4:00:22 PM(UTC)
Agitator? Motor Coupling? Dogs? (Washer Repair)
by jimotis02 9/13/2011 10:54:07 AM(UTC)
sears/kenmore motor coupling replacement (Washer Repair)
by ron_gedye 3/23/2011 11:17:29 AM(UTC)
Motor coupling (Washer Repair)
by Moxleysr 2/3/2011 1:57:12 PM(UTC)
New Universal Motor Coupling (part no AP3963893 ) (direct drive) won't fit properly (Washer Repair)
by felixq78 5/1/2010 11:12:04 PM(UTC)
kenmore 60 series not spinning after motor coupling replacement (Washer Repair)
by orion359 3/29/2010 3:56:34 PM(UTC)
Replacing New Motor Coupling (Washer Repair)
by pianoman 2/10/2010 12:09:37 PM(UTC)
