| » Stacked Washer/dryer Wont Spin/burn Smell |
Model Number: FLEB8200DS0 Brand: Frigidaire Age: 1 - 5 years
We have a stacked washer/dryer, the washer will fill up with water but wont aggitate and after a while smells like something is burning. Wont drain either. If its a bad belt, is this easy to repair? otherwise what else might i look for?
thanks. Related Models Last edited by rustknee : 03-07-2008 at 02:28 PM. |
you have an electric pump that has nothing to do with the belt, if your belt or motor was bad, it would still pump out the water... does it do anything after it fills? hum, sounds like the motor is running etc? make sure your lid switch is working and if so, i might start looking at the timer... but i don't have enough info. does it spin?
__________________
roy the appliance whisperer |
I opened up the front pannel and could hear the water pump was struggling...after taking off the hose found out a small clothing piece was caught in the pump. Removed and now its back to normal. Thanks for the info anyway.
| Display Modes | |
| washer doesnt spin all i hear is buzzing and the smell of smoke | willp3 | Washer Repair | 8 | 06-23-2009 02:45 AM |
| Dryer leaves burn marks on clothes | abusaft1 | Dryer Repair | 0 | 02-23-2008 05:17 AM |
| washer wont spin | BigMike | Washer Repair | 0 | 01-02-2008 08:37 AM |
| maytag gas dryer hums but wont start.. electric smell. | elsanto | Dryer Repair | 0 | 12-31-2007 07:49 AM |
| maytag gas dryer will not heat after initial burn | Agustin | Dryer Repair | 1 | 08-28-2007 10:48 AM |
