Discuss
Gearcase leaking
 in
Washer Repair
When I moved my washer to clean behind it, I found that the floor was covered with oil (about 2.5
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Gearcase leaking
  #1 (permalink)
Old 11-26-2009, 06:05 PM
Junior Member
DaveJ is on a distinguished road
Default Gearcase leaking
Model Number: 110.28732700   Brand: Kenmore   Age: 1 - 5 years
When I moved my washer to clean behind it, I found that the floor was covered with oil (about 2.5 foot square). Washer is less than 2 years old and, so far, seems to be working fine (no odd noises...yet). From my research, the only component that could have been leaking oil would be the gearcase. Is this a common problem for Kenmore?? Although it seems to me that Sears should cover such an issue, they say that I'm on my own since I didn't purchase the extended warranty.
So...what's my best option?
1] Purchase the seals and oil and reseal it? Is this something that I could do myself with basic hand tools (I'm pretty handy and typically fix most things myself)? Or, are special tools required? Also, would I need a gasket to seal the case? And, with it leaking for so long, would the internal components possibly have additional wear which would make this the wrong decision? Any advice you can give me on this would be appreciated!
2] Purchase a new gearcase?
Thanks,
Dave
Ads By Google
Related Models
Kenmore 110.29012990  COMMERICAL AUTOMATIC WASHER
Kenmore 110.29032990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.29072990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42836201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42922200  WASHER
Kenmore 110.42924200  WASHER
Kenmore 110.42926200  WASHER
Kenmore 110.42932200  WASHER
Kenmore 110.42934200  WASHER
Kenmore 110.42936200  WASHER
Kenmore 110.4319351  BURNER ASSEMBLY
Kenmore 110.4319410  GAS DRYER BURNER
Kenmore 110.44832200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44834200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44836200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44932200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44934200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44936200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.4760294  WASHER
Kenmore 110.4766195  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.4766295  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.48182790  AUTOMATIC WASHER
Kenmore 110.48182791  AUTOMATIC WASHER
Kenmore 110.48184790  AUTOMATIC WASHER
Kenmore 110.48184791  AUTOMATIC WASHER
Kenmore 110.48722790  COMPACT AUTOMATIC WASHER
Kenmore 110.48722791  COMPACT AUTOMATIC WASHER
Kenmore 110.48724790  COMPACT AUTOMATIC WASHER
Kenmore 110.48724791  COMPACT AUTOMATIC WASHER
Kenmore 110.49182990  AUTOMATIC WASHER
Kenmore 110.49182991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.49740  STACK STAND KIT
Kenmore 110.508802  KENMORE ELECTRIC DRYER
Kenmore 110.5807100  KENMORE GAS DRYER
Kenmore 110.5807300  KENMORE GAS DRYER
Kenmore 110.5807410  KENMORE GAS DRYER
Kenmore 110.5807500  KENMORE GAS DRYER
Kenmore 110.5807501  KENMORE GAS DRYER
Kenmore 110.5807700  KENMORE GAS DRYER
Kenmore 110.5807701  KENMORE GAS DRYER
Kenmore 110.5807800  KENMORE GAS DRYER
Kenmore 110.5807801  GAS DRYER
Kenmore 110.5807810  KENMORE GAS DRYER
Kenmore 110.5807811  KENMORE GAS DRYER
Kenmore 110.5807850  KENMORE GAS DRYER
Kenmore 110.5807851  GAS DRYER
Kenmore 110.5807860  KENMORE GAS DRYER
Kenmore 110.5807861  KENMORE GAS DRYER
Kenmore 110.5807950  KENMORE GAS DRYER
Kenmore 110.5807951  GAS DRYER
Kenmore 110.5807960  KENMORE GAS DRYER
Kenmore 110.5807961  KENMORE GAS DRYER
Kenmore 110.5808000  KENMORE ELECTRIC DRYER
Kenmore 110.5808010  KENMORE ELECTRIC DRYER
Kenmore 110.5808100  KENMORE ELECTRIC DRYER
Kenmore 110.5808300  KENMORE ELECTRIC DRYER
Kenmore 110.5808500  KENMORE ELECTRIC DRYER
Kenmore 110.5808700  KENMORE ELECTRIC DRYER
Kenmore 110.5808800  KENMORE ELECTRIC DRYER
Kenmore 110.5808810  KENMORE ELECTRIC DRYER
Kenmore 110.5808850  KENMORE ELECTRIC DRYER
Kenmore 110.5808860  KENMORE ELECTRIC DRYER
Kenmore 110.5808950  KENMORE ELECTRIC DRYER
Kenmore 110.5808960  KENMORE ELECTRIC DRYER
Kenmore 110.5817500  KENMORE GAS DRYER
Kenmore 110.5817501  KENMORE GAS DRYER
Kenmore 110.5817800  KENMORE GAS DRYER
  #2 (permalink)
Old 11-27-2009, 10:57 AM
Junior Member
SearsCare is on a distinguished road
Default
To DaveJ,
My name is Brian and I am part of the Sears Cares escalations team. I am sorry to hear about these issues with your washer and I wanted to reach out to you on behalf of Sears regarding this issue. We do have some options available for you regarding service on the washer. If you cannot reach an adequate solution on this site, we would like to help. At your convenience, please contact my office via email at searscares@searshc.com. In the email, please provide a contact phone number and the phone number the washer was purchased under (if different than the contact phone number) and we will call you directly. Also, please provide the screen name (DaveJ) used to post here for reference to your issue, and we do look forward to talking to you soon.
Thank you,
Brian J.
Senior Case Manager
Sears Cares
  #3 (permalink)
Old 11-27-2009, 11:18 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Dave
If you otherwise like the machine I suggest you replace the gear case. Your situation is not typical, but it does happen and I think you will be happier with the replacement gear case rather than trying to fix it.
If you decide to go that route it is a somewhat time consuming task, but it does not take special skills, tools or experience.
Here is the part.
Part number: AP3096209
and here is a site that will show you how to take your cabinet off to get to it. After you remove motor and the agitator, the transmission will come out by take out three screws.
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
__________________
  #4 (permalink)
Old 11-27-2009, 01:37 PM
Junior Member
Default
Brian, thanks for the post....I sent an email to the address you provided and look forward to hearing from you.
Sidfink, thanks for the advice, part number, and link to the awesome video on YouTube - I appreciate it!! The video makes it look easier than it probably is, but it gave me the confidence that I certainly could replace it myself.
-Dave
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gearcase not spinning freely hawaiiansharkus Washer Repair 1 07-15-2009 06:14 PM
Gearcase won't meet with tub support Bring Washer Repair 1 05-19-2009 05:30 PM
Gearcase leaking oil leakycauldron Washer Repair 2 02-09-2009 06:45 AM
Gearcase oil papafrita Washer Repair 1 01-22-2009 04:32 PM
Gearcase Input Shaft Oil Seal Kit jennidoug96 Washer Repair 3 06-24-2008 03:26 PM
