| » Whirlpool washer will not fill |
Model Number: LSR8233EQ0 Brand: Whirlpool Age: 5 - 10 years
The washer will not fill with water. The faucets are clear; the hoses are clear; the pump seems to be working and clear; the pump's hoses are clear. It goes into the cycles fine and shifts from one cycle to another with no problems. However, it does not want to drain completely and the wash and rinse cycle have no water filling the tub. I have cleaned the tube going into the water level switch. I have poured water into the tub to test it. Not sure where to go from here.
Related Models |
Replacement parts for WHIRLPOOL LSR8233EQ0 | AppliancePartsPros.com Here is the wiring diagram http://www.servicematters.com/docs/w...%203949340.pdf Could be that the level switch's contacts are welded together. Easiest way is to check it with a meter. Remove the wire from V then measure across V to T should be infinite ohms (open), then measure from V to the third connection should be 0 ohms. Another way would be to unplug the unit, remove the wires from V and the third connector (not T), short them together and tape them up so they cannot short to the frame. Then plug it in and give it a try, if it starts to fill the switch is probably toast.
__________________
| Display Modes | |
| Whirlpool washer will fill only | resloan | Washer Repair | 12 | 08-03-2009 12:34 PM |
| whirlpool washer will not fill! overflows | tasmbierman | Washer Repair | 0 | 12-14-2008 02:19 PM |
| Whirlpool Washer Won't Fill | bjm46 | Washer Repair | 1 | 11-15-2008 08:53 PM |
| Whirlpool washer won't fill with water | Evonne | Washer Repair | 1 | 10-22-2008 01:54 PM |
| whirlpool washer does not fill but does agitate | lambert | Washer Repair | 1 | 01-24-2008 05:04 PM |
