Discuss
Agitator Removal
 in
Washer Repair
The Whirlpool washer has a fabric softner dispenser attached at the top of the agitator. Is it necessary to remove
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Agitator Removal
  #1 (permalink)
Old 11-24-2009, 04:28 PM
Junior Member
MarthaJ is on a distinguished road
Default Agitator Removal
Model Number: LA5600XT   Brand: Whirlpool   Age: More than 10 years
The Whirlpool washer has a fabric softner dispenser attached at the top of the agitator. Is it necessary to remove the dispenser before pulling up the agitator? If so, how is the dispenser removed ? The dispenser will not turn. Don't know whether the dispenser is seized or does not separate from the top of the agitator.
Thanks.
Martha
Ads By Google
Related Models
Whirlpool LA5600XTF0
Whirlpool LA5600XTF1
Whirlpool LA5600XTG0
Whirlpool LA5600XTG1
Whirlpool LA5600XTM0
Whirlpool LA5600XTM1
Whirlpool LA5600XTN0
Whirlpool LA5600XTN1
Whirlpool LA5600XTW0
Whirlpool LA5600XTW1
Whirlpool LA5605XKW1
Frigidaire LA560AXD1 Wwh(v6) / 27 " Washer
Frigidaire LA560AXD2 Wwh(v2) / 27 " Washer
Frigidaire LA560AXW1 Wwh(v5) / 27 " Washer
Frigidaire LA560AXW2 Wwh(v1) / 27 " Washer
Frigidaire LA560JXD3 Wwh(v1) / Washer
Frigidaire LA560JXD4 Wwh(v1) / Top Load Washer
Frigidaire LA560JXD5 Wwh(v1) / Top Load Washer
Frigidaire LA560JXF3 Wwh(v2) / Washer
Frigidaire LA560JXF4 Wwh(v2) / Top Load Washer
Frigidaire LA560JXH3 Wwh(v3) / Washer
Frigidaire LA560JXH4 Wwh(v3) / Top Load Washer
Frigidaire LA560JXV3 Wwh(v4) / Washer
Frigidaire LA560JXV4 Wwh(v4) / Top Load Washer
Frigidaire LA560JXW3 Wwh(v5) / Washer
Frigidaire LA560JXW4 Wwh(v5) / Top Load Washer
Frigidaire LA560JXW5 Wwh(v2) / Top Load Washer
Frigidaire LA560MXD1 Wwh(v3) / 27 " Washer
Frigidaire LA560MXD2 Wwh(v2) / 27 " Washer
Frigidaire LA560MXH2 Wwh(v3) / 27 " Washer
Frigidaire LA560MXW1 Wwh(v1) / 27 " Washer
Frigidaire LA560MXW2 Wwh(v1) / 27 " Washer
Whirlpool LA5610XTF0
Whirlpool LA5610XTG0
Whirlpool LA5610XTG1
Whirlpool LA5610XTM0
Whirlpool LA5610XTN0
Whirlpool LA5610XTN1
Whirlpool LA5610XTW0
Whirlpool LA5610XTW1
Whirlpool LA5668XSW0
Whirlpool LA5668XSW1
Whirlpool LA5668XSW2
Whirlpool LA5668XTF1
Whirlpool LA5668XTG1
Whirlpool LA5668XTM1
Whirlpool LA5668XTN1
Whirlpool LA5668XTW0
Whirlpool LA5668XTW1
Whirlpool LA5700XKW0
Whirlpool LA5700XMW0
Whirlpool LA5700XMW1
Whirlpool LA5700XPW0
Whirlpool LA5700XPW1
Whirlpool LA5700XPW3
Whirlpool LA5700XPW4
Whirlpool LA5700XPW5
Whirlpool LA5700XPW6
Whirlpool LA5700XSW0
Whirlpool LA5700XSW1
Whirlpool LA5700XSW2
Whirlpool LA5700XTF0
Whirlpool LA5700XTF1
Whirlpool LA5700XTG0
Whirlpool LA5700XTG1
Whirlpool LA5700XTM0
Whirlpool LA5700XTM1
Whirlpool LA5700XTN0
Whirlpool LA5700XTN1
Whirlpool LA5700XTW0
Whirlpool LA5700XTW1
Whirlpool LA5705XKW0
Whirlpool LA5705XMW0
Whirlpool LA5705XMW1
Whirlpool LA5705XTF0
Whirlpool LA5705XTF1
Whirlpool LA5705XTF2
Whirlpool LA5705XTG0
Whirlpool LA5705XTG1
Whirlpool LA5705XTG2
Whirlpool LA5705XTM0
Whirlpool LA5705XTM1
Whirlpool LA5705XTM2
Whirlpool LA5705XTN0
Whirlpool LA5705XTN1
Whirlpool LA5705XTN2
Whirlpool LA5705XTW0
Whirlpool LA5705XTW1
Whirlpool LA5705XTW2
Whirlpool LA5705XWF0
Whirlpool LA5705XWG0
Whirlpool LA5705XWM0
Whirlpool LA5705XWN0
Whirlpool LA5705XWW0
Whirlpool LA5710XPW0
Whirlpool LA5710XPW1
Whirlpool LA5710XPW3
Whirlpool LA5715XPW0
Whirlpool LA5715XPW1
Whirlpool LA5715XPW3
Whirlpool LA5720XTF0
Whirlpool LA5720XTG0
Whirlpool LA5720XTM0
Whirlpool LA5720XTN0
Whirlpool LA5720XTW0
Whirlpool LA5800XKW0
Whirlpool LA5800XKW1
Whirlpool LA5800XMW0
Whirlpool LA5800XPW0
Whirlpool LA5800XPW1
Whirlpool LA5800XSW0
Whirlpool LA5800XSW1
Whirlpool LA5800XTF0
Whirlpool LA5800XTF1
Whirlpool LA5800XTG0
Whirlpool LA5800XTG1
Whirlpool LA5800XTM0
Whirlpool LA5800XTM1
Whirlpool LA5800XTN0
Whirlpool LA5800XTN1
  #2 (permalink)
Old 11-25-2009, 06:40 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Martha
The exploded view of your machine does not show a dispensor, but if you have one it should just lift out. There may be a lot of gunk which is making it difficult, but apply pressure and it should come off. Just be careful it does not release all at once and bop you in the face. (Been there, done that)
You will then find a plastic cap which will come out, and underneat that is a bolt which you can remove with a socket wrench and an extension. Should be 7/16" head.
The agitator will then left out, but again it may be hard to do from laundry gunk.
Click on your model number to see an exploded view of the agitator.
Good luck.
__________________
  #3 (permalink)
Old 11-27-2009, 10:36 AM
Junior Member
Default
MY washer model LA5600XT is not in your database. I have only used the dispenser once, then attempted to remove it to rinse it out. But was unable to remove it. Most likely it was stuck when it was delivered.
Martha
  #4 (permalink)
Old 11-27-2009, 11:09 AM
Senior Expert
APP Volunteer
Default
On some models there is an aqua plastic ring that must be moved up to release the fabric softener. See if there is one on yours.
Here is an exploded view of what should be your model.
Agitator, basket and tub replacement parts for WHIRLPOOL LA5600XTF0 | AppliancePartsPros.com
If you cannot get it off then I have no other suggestion but breaking it, which I hate to suggest.
__________________
  #5 (permalink)
Old 11-29-2009, 06:58 AM
Junior Member
Default
11/29/2009
I found the full model number on the plate attached to the washer LA5600XTW0. I was using the number from the user manual which was not complete.
I removed the softener dispenser. Up near the top of the dispenser is a slight rim. I used a putty knife to lift up on the dispenser at the rim and it came out. It has small plastic protrusions that secure it in the opening.
It is 6 1/2 inches in length. Wide at the top and tapered at the bottom. Someone with a firm grip can probably just pull up on it to remove it. Also it's kind of wide at the top for the average female hand.
Thank you much.
Martha
  #6 (permalink)
Old 11-29-2009, 07:13 AM
Senior Expert
APP Volunteer
Default
Great, glad you got it off and if you need any more help just post.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
agitator removal brownnines Washer Repair 2 10-11-2009 12:40 PM
Agitator Removal LTP Washer Repair 1 06-23-2009 06:17 PM
Agitator Removal awookiecookie Washer Repair 0 02-05-2009 04:11 PM
Agitator Removal WOODSAL Washer Repair 1 01-30-2009 02:19 AM
ge agitator removal mc1253 Washer Repair 0 10-20-2008 06:21 PM
