I have an energy saver model which has a permanent flow control on the hot water inlet and also a thermostat to limit the maximum hot water temperature to I think 115 deg F.
Is there a way to remove the flow restrictor on the hot water inlet to obtain a much hotter hot water setting?
stonooka
