Discuss
White Westinghouse Washer won't drain and has burnt rubber smell
 in
Washer Repair
I have a washer that just started to smell of burnt rubber and it did not drain. I took off
Appliance Repair Forum > Appliance Repair Help > Washer Repair » White Westinghouse Washer won't drain and has burnt rubber smell
  #1 (permalink)
Old 11-24-2009, 10:35 AM
Junior Member
brandiannh is on a distinguished road
Default White Westinghouse Washer won't drain and has burnt rubber smell
Brand: White-Westinghouse   Age: 5 - 10 years
I have a washer that just started to smell of burnt rubber and it did not drain. I took off the front to see it it was the belt again and that is fine. I ran it and the water comes in but does not drain all the way. Everything underneath was spinning and sounding ok.
  #2 (permalink)
Old 11-27-2009, 10:41 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
I would check the pump and drain hoses. If you need more info please post a model number and any more description you think would be helpful.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Will not spin, burnt rubber smell? Gerry O Washer Repair 2 10-19-2009 11:33 AM
No spin burnt rubber smell screeching sound tinkerman745 Washer Repair 5 09-15-2009 01:41 AM
Burnt Rubber Smell 1TechDad Washer Repair 1 09-06-2009 07:41 AM
Burnt Rubber Smell & Smoke hchatton Washer Repair 1 10-24-2008 03:33 PM
White Westinghouse washer won't spin help_me_please Washer Repair 1 09-19-2007 04:29 AM
