MACHINE WORKS FINE UNTIL IT GETS TO THE RINSE CYCLE AND AFTER IT PUMPS THE WATER OUT IT HANGS UP AND THE PUMP KEEPS RUNNING AND IT WILL NOT ADVANCE TO THE NEXT CYCLE UNTIL YOU UNPLUG IT FOR 30 MINUTES THEN IT WILL ADVANCE ON LIKE IT IS SUPPOSE TO, IS IT THE MICRO COMPUTER OR THE INTERFACE BOARD.........
I assume your model number is GHW9100 and not what you posted.
About all I can say is to find the tech notes that are either under the top or inside the lower service panel and try to put the machine into test mode. I suspect the problem is your control board, but since it is expensive see if you can get the tests to confirm or support that theory.
