my washer fill with water but the program does not advance the rinse and spin cycles work when advanced manually please give me a solution to this problem
If the machine goes through the agitate, drain, spin, fill, rinse agitate, drain, spin process ok after you nudge the timer forward then it is probably the timer. Fortunately this one is not expensive. Part number: AP3604424
