| » Washer tub leak at hose |
Model Number: ALW480DAW Brand: Amana Age: 1 - 5 years
My washer is leaking around the hose that connects to the plactic tube on the outer tub. Tightening the hose clamp doesn't help. The hose and the plastic tube appear to be ok. Is there another seal from the tub that connects to this plastic tube?
Replace the parts in this diagram and you should be all set.
Outer tub and pressure tube replacement parts for AMANA ALW480DAW | AppliancePartsPros.com
__________________
Like the earlier poster from 2 years ago, I have an Amana ALW480DAW that just started to leak. I immediately opened the front and noticed water leaking from the plastic tube coming from the bottom of the tub. I thought this would be an easy fix by just tightening the hose clamp. But that didn't solve the problem.
********* Post Edit Update to the above. After watching closer it's obvious I have a seal leak. I filled the tub again and used a better flashlight. Water was obviously dripping around the triangle seal. Is the full kit recommended? Or can I just purchase the main seal? Obviously, I'm looking at price. Thoughts? Thanks, Jim Last edited by jimoshea : 05-10-2011 at 06:24 PM. |
| Display Modes | |
| water dispenser hose leak | jnowicky | Refrigerator & Freezer Repair | 0 | 06-21-2009 01:10 PM |
| Leak in hose | Limms | Washer Repair | 1 | 06-01-2009 03:49 PM |
| leak drain hose | bigstormy | Washer Repair | 0 | 03-02-2009 08:16 AM |
| "Water won't come out of the hose from the washer | caroldvs | Washer Repair | 4 | 10-13-2008 03:28 PM |
