| » Motor play causing trouble |
Model Number: pavt244aww Brand: Maytag Age: 5 - 10 years
Noisy washer during agitate/spin.
The belt has been replace. After replacement the noise was gone - but mid cycle it came back. The cover was open, I pulled to motor to make the belt tighter and the noise went away. Seem like to motor is mounted to have play - I don't see how I can tighten it up. There is a pin - I wonder if this is what governs the play. The pin doesn't look bad. How can I increase tension on the belt? Ads By Google Related Models |
Two things you need to check for. Make sure the motor is free to move back and forth freely. It should free float so to speak. Next make sure the water pump is turns freely by removing the belt and turning it by hand. If the pump gets tight the belt will slip and this is a common problem with this machine. Clothes Washer Repair Guide
| Display Modes | |
| Pump Motor has Trouble Starting | jmrec100 | Dishwasher Repair | 0 | 11-21-2009 05:32 PM |
| F+P Dryer Motor Shaft Play | bb4u | Dryer Repair | 3 | 07-07-2009 06:55 PM |
| motor trouble | 2767D | Washer Repair | 1 | 05-11-2009 03:58 PM |
| motor shaft play | plubbers | Dryer Repair | 1 | 04-01-2008 01:02 PM |
| Motor trouble | GeorgeG | Washer Repair | 2 | 03-29-2008 09:58 PM |
