| » roper washer |
Model Number: rtw4305vq1 Brand: Roper Age: Less than 1 year
When my washer calls for hot water I get none. I have hot water going to the machine and the screens are clean. In the warm setting all I get is cold water.
Related Models Last edited by snallac : 11-20-2009 at 05:50 AM. |
Here are the parts
Replacement parts for rtw4305vq1 models | AppliancePartsPros.com Here is the wiring diagram http://www.servicematters.com/docs/w...0W10118358.pdf Here is some info on your temperature control https://secured.whirlpool.com/Servic...LE/4322334.pdf I would swap the wires going to the hot and cold valves. If the unit now fills with hot water the problem is likely in the temperature switch which looks like it is also the ATC (Automatic Temperature Control). I would check the thermistor just to be sure it is OK
__________________
| Display Modes | |
| roper washer | muttavous | Washer Repair | 2 | 03-07-2009 06:57 PM |
| roper washer | michelle whelan | Washer Repair | 2 | 02-24-2009 03:41 PM |
| Roper Washer Not Draining | julieann | Oven Repair (including Ranges and Cooktops) | 2 | 11-26-2008 06:21 AM |
| Roper washer Needs Help | shane k | Washer Repair | 1 | 07-16-2008 04:57 PM |
| roper washer question | whitehanes34 | Washer Repair | 2 | 12-02-2007 12:03 PM |
