| » Maytag Neptune squeaking noise |
Model Number: MAH7500AWW Brand: Maytag Age: More than 10 years
Maytag Neptune MAH7500AWW is making a squeaking noise when the tub is rotating. It sounds like a rubber squeak such as a auto fan belt. Checked the belt and it appears in good shape. Can anyone help?
Difficult to say since the main method by which we diagnose a noise is to listen to it.
Given the age of your machine the most likely problem is a bearing beginning to fail. This is not repairable, and it is not economically feasible to replace the outer tub. It may be some noise from the seal, in which case you can attempt to repair it. Here is the part. Part number: AP4009088 and here is a service manual for your machine. http://www.servicematters.com/maytag...s/16010061.pdf
__________________
| Display Modes | |
| Squeaking noise coming from motor | J.T. | Dryer Repair | 6 | 10-27-2009 07:02 PM |
| Loud squeaking Noise | Peter687 | Dryer Repair | 4 | 09-24-2009 12:01 PM |
| Squeaking noise when agitaites | justjudy | Washer Repair | 1 | 09-20-2009 04:08 PM |
| squeaking noise | tesslef | Dryer Repair | 1 | 07-29-2009 02:39 PM |
| Loud Squeaking Noise | bdmcgal | Dryer Repair | 1 | 12-10-2008 07:13 PM |
