Discuss
Washer Spins only after lifting top lid
 in
Washer Repair
I have the Whirlpool LSQ8243HQO washing machine and have replaced the motor coupling for the 2nd time. One thing I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Spins only after lifting top lid
  #1 (permalink)
Old 11-17-2009, 06:11 PM
Junior Member
yotaman2112 is on a distinguished road
Default Washer Spins only after lifting top lid
Brand: Whirlpool   Age: 5 - 10 years
I have the Whirlpool LSQ8243HQO washing machine and have replaced the motor coupling for the 2nd time. One thing I hadn't noticed was that it agitates fine. The problem is when it dumps the 1st drain. It won't spin. If I lift the lid on it THEN it gives an indication that it has 'caught' in gear then starts spinning. It will spin for about 2 minutes (I didn't time it) then restarts to spin again then repeats the same thing on the final spin. I feel it's the transmission, but not sure. Any ideas?
Ads By Google
  #2 (permalink)
Old 11-19-2009, 03:50 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Your machine has what is called a neutral drain. While the tub is draining the transmission is in neutral, so that it is not trying to spin a tub full of water. After the water drains the motor must pause for the transmission to shift into spin.
In your case the motor does not pause, so when you open the lid you are pausing it manually, which causes the machine to then go into spin. The problem is your timer, not your transmission which is good news as it is a less expensive part and easier to replace.
If you want to wait it out, you can keep raising the lid to start the spin, and sometimes the timer will work its problem out on its own.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Lifting Top CHIEFBOB Washer Repair 1 10-20-2009 09:27 AM
Lifting washer top Waltb Washer Repair 1 06-18-2009 03:50 PM
washer some what spins kent pratt Washer Repair 0 03-02-2008 03:18 PM
Lifting Main top on Gas range vornato Oven Repair (including Ranges and Cooktops) 5 12-12-2007 02:56 PM
lifting the door davcat5 Refrigerator & Freezer Repair 0 08-11-2007 06:09 AM
